My phillips model # 50P8341 periodically shuts off on its own. When I turn it back on it plays for a little while then shuts off again.
  • Pipermaru2u May 05, 2009
    My tv turns itself off after like 30 to 60 mins. And the color is weird and 3d looking, And it has a arch on the bottom of the left hand side corner
  • 8,617 Answers
The set is going into shutdown mode. does the power indicator blink when it shuts down. If so how n=many blinks does it blink?
Posted on Apr 28, 2008
Phillips 50P8341 will stay on about 15 mins then shuts off then the power button flashes twice, pauses then flashes twice again...
Seems like it is overheating. Try cooling it down by using a fan to blow air into it (temporary fix). Make sure the TV is well ventilated and heat can escape (permanent solution).
Jan 15, 2011 | Philips 50P8341 50" Rear Projection...
I have a philips rear projection tv 50p8341 it comes on for a while then turns off and you have to leave it set for a little while then it will come back on for a few mins and then shut back off then wont...
Once again...you need the ssb Part# PH3912725871. Follow the instructions on the instructions that accompanies this part. Your main concern will to adjust the geometry.
Oct 27, 2009 | Philips 50P8341 50" Rear Projection...
My phillips 50p8341 tv has had several problems over the years 1st being the remote quit working now the tv is turning of and the light is flashing and won't stay on.
Chances are you will the small signal board. Donot confuse it with the small signal module. You will be replacing a board the size of a playing card. Part# PH3912725871. Follow the instructions that accompany this part. Mainly you will have to adjust the geomtry.
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
Power light always on but no pic
Make sure it is off when you unplug it, do not use for at least a few days then.try again. It worked for mine.
Jun 20, 2009 | Philips 50P8341 50" Rear Projection...
Phillips magnovax 50p8341
sounds like the LSB ( large signal board) as that has all the various power supplies on it. You can get a replacement board at the following link.
http://servicemanuals.vstore.ca/
Aug 04, 2008 | Philips 50P8341 50" Rear Projection...
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Rear projection
Considering that in both cases, the set will turn on but not stay on, indicates either a condition of overheating due to a failed fan or it could be a component going into thermal runaway in the power supply itself that is causing the fault.
This is not a safe area to probe around in since there are capacitors that may contain a charge for a fairly long time.
If the fan cannot be heard, this is probably a cheap repair, otherwise, get an estimate first.
Jan 11, 2008 | Philips 50P8341 50" Rear Projection...
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
