Question about Canon Pixma MP450 All-In-One InkJet Printer
Error code 5100
Printer worked fine yesterday. what's going on?
  • 2 more comments
  • Lajman May 12, 2008
    Having the same problem, error code 5100 sometimes it works some times it doesn't.Seems to be a common problem with a lot of people,wouldn't you think Canon would post a fix for the problem????
  • Anonymous Jun 03, 2008
    code 5100--worked four hours ago. followed instruct to turn off, wait and try again--still 5100
  • Anonymous Jun 16, 2008
    Geachte,
    Er verschijnt foutcode 5100.Na het uitschakelen en weer in schakelen is het nog altijd foutcode 5100.Het toestel is in garantie aankoop Aldi.
    Kan je mij helpen?
    michel.bryon@telenet.be
    Met dank,
    Michel Bryon
    Catstraat 30
    8680 KOEKELARE
  • Anonymous Jul 29, 2008
    following instuctions to turn off and back on, but still not working. three days now! HELP!
  • 4,041 Answers
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
eror code is
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Feb 01, 2010
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
Canon MP560 Gets error code 5100
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Canon MP560 All-In-One InkJet Printer
Canon MP600 Printer - How do I fix error code 5100
Hi Whitey621
Error code 5100 Try
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Gently clean this strip with a damp lint-free tissue
Hope It Helps: Pineworks.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have a ip5000 that has service error code 5100
I had the same problem. all i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine.
Tips:
#1 Move the cartridge holder back to the right manually, but carefully - close lid and turn the printer off, then on again.
#2 Move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Aug 10, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon printer mp460error code 5100
Service Error 5100 is Displayed
Cause
Action
Movement of the FINE Cartridge Holder is blocked.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Nov 05, 2008 | Office Equipment & Supplies
Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It could mean the rollers don't grip the paper, there is torn paper keeping the rollers from turning, the paper can't stick to the rollers etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Sep 01, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon pixma450 printer error code 5100
go crazy and hit it will work relly i tried it
Nov 18, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
164 people viewed this question
old marine
old marine
