Question about Nokia 6133 Cellular Phone
Opening back panel
How do you get the back of the nokia 6133 open. i have struggled with it. i can't slide it open or any button to press please help i need to get to my sim card
On the back of the phone sort of at the bottom use your thumb to slightly push down and slide up and it should come off. If that doesn't work for you at the top there is a compartment beside where the charger goes that can open. Use your nail to slightly pop it open just a little nudge. Then you can try the other part where you push down with your thumb and slide off the back. It is confusing but, once you get the hang of it....piece of cake.
Posted on May 12, 2008
Hard locked nokia 6133
1 - Switch on your Nokia 6133 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6133.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6133 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6133 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6133
Each Nokia 6133 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 6133 mobile phone at
Feb 15, 2012 | Nokia 6133 Cellular Phone
How to set my nokia 6133 to vibration?
hi
please press and hold the # key for 6 second .. it will set your phone to vibration mode .. to get back to normal mode again press and hold the # key for 6 seconds ..
Sep 19, 2011 | Nokia 6133 Cellular Phone
How to format nokia 6133
hi,
  1. Power on the Nokia 6133. Turn the Nokia 6133 on and allow it to load the home screen.
  2. Navigate to options. Press the "Menu" key on the Nokia 6133. Select "Options" and press "OK".
  3. Select the memory card folder. Highlight the memory card folder. Press "OK".
  4. Select options. Select "Options". Highlight "Format memory card".
  5. Confirm the format. When prompted, select "Yes". Wait patiently while the Nokia 6133 formats the memory card.
  6. Enter a name. When the Nokia 6133 is finished formatting the memory card it will ask you for a name. Enter a name into the Nokia 6133 for the memory card. The Nokia 6133 allows the name to be up to eleven characters and numbers.
Aug 02, 2010 | Nokia 6133 Cellular Phone
I cannot remove the back cover of Nokia 6600 slide,have tried pushing and pressing the button but nothing,lyn
I loved my Nokia slide, but whenever I needed to get the back off I ended up going back to the shop, every time!! It just would not come off. The boys in there couldn't get it off without a struggle either. Design glitch they called it. Perhaps it eases in time, but its the same old story you just cannot force it at all. I have another phone now - same problem!!
Apr 26, 2009 | Nokia 6600 slide Cellular Phone
HELP
Open phone, don't go to any menus. Dial *#7780# and press green send button. It will say if you would like to restore factory settings and say yes. Then it asks for a code. This is when you put 12345 and then press OK. This should help because it did for me.
GOOD LUCK!!
Sep 08, 2008 | Nokia 6133 Cellular Phone
Nokia 6133 blank screens and no loudspeaker
I have the same problem two weeks ago. I opened my phone and kept it under the table lamp to dry off some moisture and my screen came back and working good.
Also tried to reset it by taking out Sim card press *3 send button together when turn on the phone ,it will take a while ,but it will reset the phone and will ask for the sim card info.
It fixed my problem ,so hope no harm to try that.
Thanks
Jul 29, 2008 | Nokia 6133 Cellular Phone
Nokia 6133 LCD Replacement Trouble
my guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Feb 14, 2008 | Nokia 6133 Cellular Phone
STILL NO HELP
try to replace a new LCD...
Jan 22, 2008 | Nokia 6133 Cellular Phone
Lcd screen replacement
On the front side of the phone above the camera eye you can carefully (either with your fingernail or a small screwdriver) pry the plastic apart. Once you have the top apart a little bit work your way down each side, once the top and sides are loose you can slide the cover up and off. Once open ther will be a green board around and over the lcd, remove two small connectors on the top and one small one on the bottom underneath the board. When the green board is off look on the sides of the LCD and you will see four points securing it into the phone, carefully pry out on each of these and you can then remove the LCD. Replacement is reverse. Good luck.
Dec 07, 2007 | Nokia 6133 Cellular Phone
Nokia 6133 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
