Question about Kitchen Ranges
Simpson harmony nova oven , oven is heating up but fan wont work and oven does not heat enough to use.
  • Anonymous Sep 03, 2008
    simpson nova thermaflow oven is heating up but fan doesnt work so heat is not maintained
  • andree coumbe May 22, 2013
    how do you change the oven light
I had same problem. Replaced fan motor,really easy,but still would not turn. Got my brother inlaw to check it. Turns out it was the thermostat. He gave the connections a cleanup with sand paper, like you do car spark plugs. Works great,
Posted on Apr 21, 2009
Simpson nova thermaflow oven grill when selected will not heat up.Fan operates but oven light does not illuminate as well.Any solutions please?
Posted on Sep 20, 2010
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Simpson Nova oven model 63-538 fan and light not working
I have the same oven and the fan doesnt work intermittantly. I turn it on and off a few times and if that doesnt work I give the fan a push with the handle of a wooden spoon. Works so far so I havent bothered with a 'real' fix as yet.
May 21, 2012 | Electrolux Ovens
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
May 26, 2010 | Ovens
Looking for manual simpson nova 63538
how does the clock work an how do you reset it
May 13, 2010 | Ovens
Griller on simpson harmony nova oven
In my experience, it is normal to leave the the door open when grilling, otherwise it is liable to cause the bakelite handle of the grilling pan to get very hot, and possibly melt or catch fire, and make it to hot to hold the handle.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Ovens
Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Jun 01, 2008 | Ovens
Kitchen Ranges Logo
1,522 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
