Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The television I have the screen is right one moment and then the next it will shrink down and if you leave it on the channel for a little while it will stay normal and sometimes shrink down but if you flip through the channels it will stay shrinked down just got the television would like to know what is wrong. It is a Philips Magnavox model number 9P5034C103 and serial number 55510462 assembled in Greenville, TN
  • mrepstock Aug 03, 2008
    I am having the exact same problem. It did that for a while and when I left it on a channel for some time, the picture would return to full size. Now I am not getting anything when I turn on the tv. Blank screen and no sound. What is going on?
  • Philips Master
  • 3,459 Answers
This is a common problem with some older models. Check the site www.magnavoxhelp.com to see if they have a repair kit for your set.
Posted on Aug 13, 2008
The screen will shrink down. It is a Philips Magnavox model number 9P5034C102
Posted on Aug 07, 2008
POWER SUPPLY PROBLEM IN T.V
Posted on Aug 12, 2008
Page seems to be too wide for monitor screen. when centering up down & sideways either I lose some on the left or right of screen or a little on both sides. How can I shrink display Now I have only art...
It sounds like the resolution on your machine is set too large for the screen. Right click somewhere on your desktop where there is no icon. Assuming you are using Windows 7, there should be a Screen Resolution option in the little menu that appears - click on that, then try changing the resolution to 1366x768, which may even say Recommended next to it in brackets. If that still doesn't seem right, try some of the others, until you are happy with the display.
Hope this helps.
Jul 25, 2011 | Compaq Presario CQ56110US Laptop
I need to ask how to reset margins on my home page. I cannot see the print on the right hand side at all.
in your home page hold CTRL and scroll down with your middle mouse scrolling button, you will see the screen will shrink little by little when you scrolling it down.
Jul 04, 2011 | Dell Dimension 2400 PC Desktop
Cannot retune freeview on flat screen samsung
Hello Terri
Let's see if we can get you sorted out.
Make sure that you first of all have an aerial cable plugged into the TV.
Secondly make sure that you have it on a DTV (freeview channel) once you are at this stage press the MENU button on the remote. then go down to CHANNEL then across to Auto store and then follow the on screen messages.
That should be you all sorted out. If not then you may not be getting a strong enough signal from you aerial.
Hope all goes well. Please leave a thumbs up
Cheers
Little Dish Fitter.
Oct 07, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Picture shrinks toward the center of the screen
Common problem with Philips sets.
If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original chips, email/phone support, etc.
Jun 11, 2009 | Philips Televison & Video
Phillips Magnavox 9P6040-C101-60" Rear Projection Television
You can get a repair kit for the shrinking/expanding on www.magnavoxhelp.com. This is a common problem with this model.
Sep 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Accidentally changed height somehow while using remote, now "squeezed"
ou will need to adjust that via the service menu. Toshiba has 2 ways to access it on various models I will post them both. first way
1. TV turned on
2. Press 'Mute' button on the remote.
3. Press 'Mute' button on the remote again and hold.
4. Press the 'Menu' button at the TV.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the item.
5. Write down the old value of the item before changing.
6. Use Volume up and down adjust the value.
7. When you have made all the adjustments you want turn the set off to exit.
Feb 10, 2008 | Toshiba TZ50V51 50" Rear Projection...
Channel changing on PROSCAN 32LA25Q
I had the same problem, what fixed it for me was to set auto scan to setup all the channels for me again. Another thing to check would be whether it is set up to use CATV or AIR.
Dec 26, 2007 | Televison & Video
Tv horizontal and vertical
hAS THIS BEEN ANSWERED YET BECAUSE I HAVE SAME PROBLEM!?
Dec 09, 2007 | RCA 32V420T 32" TV
Screen shrinking
You have bad solder connections on the vertical output IC or on one or more of the surrounding components. Good Luck
Jul 21, 2007 | Toshiba 36A40 36" TV
Shrinking Picture
sounds like your main power supplyis going bad . It supose to be 130 dc but I'll bet its down to around 90 to 100 volts!!! its probably the main filter cap or the regulator IC . hard to say without measureing the b+ good luck
May 01, 2006 | RCA HD61LPW42 61" Rear Projection HDTV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
241 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
