FixYa.com
Tags:
Maytag Neptune MAH5500B Front Load Washer
The washer stopts immediately after it starts (by 2 users)
posted by debjit1965 on Apr 28, 2008
The washer starts with water flowing in. But almost immediately it stops with the error code "Lr".
Please let me know what is going on.
Thanks,
-Debjit
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 07, 2008
Same code as debjit1965's. Washer starts, fills with water, sits a few minutes, then stops with fault Lr. Water pump seems ok, took hoses off, it runs, nothing plugged, just doesn't do anything. No solution yet.
Best Solution
posted on May 14, 2008
FixYa! (100)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 286 votes
1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced .
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
bearing
Sounds like a bearing going... Answer This...
not spinning, not drying
washer is not drying Washer... Answer This...
MAH8700AWW
We were washing a load and the... Answer This...
can someone help me please,,,,,...
the ccu board went bad, I put... Answer This...
Maytab Neptune FL washer
the lights on the panel won't... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
