Question about Dynex DX-E401 Router
Adding a wireless connection to an existing wired network
Presently I have clearwire dsl It is connected to a (wired) dynex router there are 2 available ethernet ports I just aquired a laptop (with built in wlan) what product do I need to add a wireless connection to my existing isp ( for internet use only)? there will be no pc to pc communication.
    Novelist:
  • 125 Answers
Go out to you local electronics store and purchase a wireless router , or Wireless Access Point (AP) , this way you will create a wireless connection by following the instructions given when you purchase the Wireless AP .
Basically when you buy the Wireless router or AP you just need to plug your existing Modem/Router into the WAN port on the Wireless Router / AP and then some initial setup to configure the wireless settings and then the appropriate settings inputted on your PC.
Heres a short guide i wrote to setting up a Wireless Connections
::Click Here::
Goodluck
Posted on Apr 28, 2008
After connecting my Dynex DX-E402 wifi router to my desktop computer and running the Quick Setup on the router website I still cannot connect to the internet nor will my Netflix-ready DVD player connect to...
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
Nov 03, 2017 | Dynex DX-E402 Router
How do i hook up my router?
There are several ways to do this, depending on how your network is configured.
Generally, if you have only one router - you connect the network jack of your cable modem or DSL modem to the WAN ("wide area network" or "internet") jack of the router with a CAT 5 network cable or jumper. Each computer's network jack would be connected to one of the router's (4) LAN ("local area network" or "home network") jacks labeled 1, 2, 3, & 4.
In the picture above, the left most jack (WAN) of the router connects to the cable or DSL modem. The "LAN" jacks labeled "1, 2, 3 & 4" connect to each computer's network jack in your home.
The above would change if you are simply adding this router to extend an existing network. You'd likely be using this router as a switch, and leaving the routing duties to the main router. Over simplified, all the CAT 5 network cables would be connected to the 4 LAN jacks. There would be no connection to the router's WAN jack because the output of the first router provides only private IP addresses used in YOUR location. The internet IP address from your ISP is used only at the first router so that your entire home has the single IP address. The WAN jack is for internet addresses only - and the LAN jacks are for local / private addresses in your home only.
Have a look at the LinkSys web site for help configuring your particular model router, or reply with the model and version here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 28, 2011 | Linksys Wireless-G Broadband Router
Router working as Access Point, unable to access via we browser
Please try first plug out the router and plug in again then press & hold the reset button till the power led become red and release. If that doesn't work, plug out the router, pressing and holding the reset button plug in the router.
Let me know the result please.
Thanks for joining Fixya.
Have a good day.
Feb 22, 2010 | Dynex Wireless-G Broadband Router
I have a DGL-4100 behind a Linksys DSL router 2 networks don't.
zSB(3,3) Installing a Two Router Network Installing a router to work as the second one on a home network requires special configuration. Do the following on the second router to ensure it (and the devices attached) function properly:
    1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
    2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
    3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Oct 10, 2009 | Computers & Internet
How do I find the WEP Code for my Wireless G Dynex?
The wep key is setup on the wireless router, not the adapter. If you do not have the login information for the router, then the easiest thing to do is reset the router to default settings (this removes any existing keys) and then configure it with a new key. If you reset the router, you will need to connect to the router with a network cable to reconfigure it.
Oct 07, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Router installation
You do not have to uninstall your existing router. You can connect the new router to one of the ports on the old router.
But why would you do that? All wireless routers also have ports for wired connections. You are adding an additional possible point of failure in your network. Unless you have a good reason, keep it simple.
Jan 08, 2009 | Computers & Internet
Problems with Intel Pro/Wireless 2200BG Network Connection - Constantly connects and disconnects me from web?
Try using the Sony with an external wi fi adapter. The internal one could be bogus. Before adding new one, go into Device Manager and Disable the existing one in your Sony. Then add the new one with its software.
Aug 29, 2017 | Xterasys XN-2523G 802.11g/b (xn2523g)...
Dynex
just plug the network cable to the pc and linksys device
Apr 06, 2008 | Computers & Internet
Establishing a Network Connection
First whether the connection is pinging or not if pinging means its working may be the ip address problem
Feb 14, 2008 | Computers & Internet
Computers & Internet Logo
230 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
