Question about Garmin iQue 3600 GPS Receiver
Ique 3600 does not work why?
This unit had been working very good for many years until I put the new software upgrade . Release 6, as of Aug 09, 2007 now everything works good but when flip the antenna for finding satellites like used to do it never find anything just it is trying to find them without any result and after many minutes says that I am indoor and if I want try again or cancel it, but I am outside what happen???
  • Roman A. Jan 02, 2009
    Suddenly my Garmin iQue3600 stopped to find any sattalite. It was working fine for 5 years. I was driving from Toronto to Qubec and it was working. It was working in Qubec too. I turned it on in the middle of the way back to Toronto and it couldn"t find sattelites. I set up new location but it didn"t work. Since that time it still doesn"t work.
IQue 3600 - mine had the same trouble, but a new external antenna solved the problem. I'm guessing that the "Flip-up Antenna" goes bad after awhile. There are many who use the external antenna. Check Ebay.. buy a new one, not used. Best Wishes, Mark.
Posted on Mar 07, 2009
  • 3 Answers
Well unfortunately, sounds like it's replacement time.... same problem I had with mine. Even with an external antenna...no or little signal. Garmin charges $200 canadian for an exchange unit.
So much for costumer support.
Good luck.
Posted on May 06, 2008
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
Data card and frozen screen
HI,
Please reset it and your problem will be solved.
Jul 15, 2008 | Garmin iQue 3600 GPS Receiver
Hot sync problem for Garmin iQue 3600
If reinstalling on the same computer with your original cd doesnt' work then I suspect that your registry has gotten corrupted somehow.
I'd find another computer and try a totally new install to see if that works. This registry stuff is a headache.
If it works on a different computer then I'd go into the registry and remove all traces of Palm and ique and start all over. Always make a backup of your registry before messing around with it. If the original CD worked before then there's no reason to download newer versions unless you are wanting to solve some other problems.
Don
Jan 27, 2010 | Garmin iQue 3600 GPS Receiver
My old garmin 3600 Ique has some problems. I
the software for running the maps is not compatible is the cause.
Nov 04, 2009 | Garmin iQue 3600 GPS Receiver
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
Ique 3600
Even new, the battery is a 3600 sore spot.
If it has been left uncharged for two years, it is probably garbage.
I got a new and improved one for mine for about 30 bucks.
Try BraunOni, Eruope, I think, but the service was great.
May 04, 2008 | Garmin iQue 3600 GPS Receiver
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
Garmin 3600 GPS issue
I just started having the same problem today too. Go to preferences for gps. I did it by clicking down where the battery symbol is and where the satellite indicator comes up. Then click the quegps in the top left hand corner of the screen. Click preferences and disable WAAS. Seemed to work fine after that. I would like to have WAAS enabled so if you find anything else let me know. Wierd that happened on same day. Let me know s.conley@hotmail.com.
Sep 25, 2007 | Garmin iQue 3600 GPS Receiver
Unit will not charge, changed battery but still does not work... Help
Sound as though you shorted something on the main board when you installed the new battery. Just sell the unit for parts on Ebay
May 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
122 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
