Question about Whirlpool Dishwashers
Whirlpool quiet partner II dishwasher model DU1145XTPB7 is not cleaning dishes properly. Leaves white residue on dishes and glasses that must be scoured off by hand.
4 Suggested Answers
  • 677 Answers
SOURCE: whirlpool dishwasher QUIET PARTNER II doesn't
it is not your dishwasher that is the problem it is actually your hard water. the minerals from hard water dry and leave a white/residue. www.dishwasherfilter.com has a new product out just for this annoying problem. it filters out the hard minerals before they enter your dishwasher. it will leave your dishes crystal clean after the first load guaranteed. it is very affordable and comes with a mone back guarnatee also.
Posted on Aug 22, 2009
rylee_smith
  • 8619 Answers
SOURCE: Not cleaning dishes clearly
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 11, 2009
Testimonial: "Wow...terrific ideas...I believe it is my water pressure Thank you"
jcfs259
  • 177 Answers
SOURCE: Dishwasher leaves upper rack dishes
Your water pressure is not high enough in the dishwasher to wash the dishes on the top rack. The most common reason is that the pump in your dishwasher cannot pump fast enough to keep the water pressure up. That is because the shaft that drives the pump impeller also drives the macerator cutter that grinds up bits of food fine enough for it to pass through the screen and out to the drain. Over time, small bits of bone, broken glass, eggshell, and other items that are too strong to be cut up by the cutter end up sitting in the area where it has to spin, and they prevent it from spinning fast enough to pump enough water to the top rack with any pressure. It is simple enough to repair. You need to take out the racks, remove the bottom arm and clean out the little macerator. Once that is done, it should work great again.
Posted on Feb 22, 2011
I have a whirlpool quiet partner and it will not clean the dishes...leaves soap in compartment and all over dishes.
Hello Kristy;
My name is Peter. I am a retired field service appliance technician.
It sounds like you are plugged up.
You did not provide a model number so I have to advise you in general terms.
If you have a dishwasher which requires the high efficiency detergent and you are using regular less expensive detergent, then you are going to plug up
You need to clean your drain and float or filter. Soap film will build up and prevent you from properly draining.
Get a good dishwasher cleaning solution and cycle that.
Dec 20, 2014 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Our dishwasher doesn't seem to be getting the dishes clean anymore and leaves a residue. We have changed detergents and all that, but to no avail. Is there a filter or something that needs to be cleaned...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 11, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have just moved into a home with a 1 year old Whirlpool Gold GU2400XTP Quiet Partner III. THE DISHES ARE NOT CLEAN, GLASSES HAVE WHITE SPOTS, SILVERWARE AND PLASTICWARE HAVE WHITE FILM. I am using...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool dishwasher QUIET PARTNER II doesn't clean dishes, leaves film
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Aug 15, 2009 | Dishwashers
My whirlpool gold quiet II doesn't clean well. leaves residual stuff on dishes. Is there a filter I do not know about That I should clean?
no there is no filter to clean or change,have you put drying agent in your unit? like jet dry or somrthing like that? try some this might help.
Aug 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool quiet partner II dishwasher is leaving chunky residue on dishes
I H AWHIRLPOOL DASHWASHER MODEL # DUII45XTPB6 quite partner ll I lost my manual , Im trying to acess the error codes . or Im trying to get the diagnostic codes to start . Hope some one can Help""""""
Oct 19, 2008 | Whirlpool Dishwashers
Dishwashers Logo
128 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
