Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire refrigerator Hi.  I've noticed all your post and all are very helpful.  My Frigidaire refrigerator model# FRS26KF7Aw6 stopped running.  The condenser fan runs, but the compressor won't.  Not getting cold at all.  When I plug in the power cord, after a few seconds I get about 15 amps at the compressor wires for about 10 seconds, than a relay or overload protector clicks and looses power.  This will happen over and over.  I'm guessing the starter or bad compressor.  If the starter is bad will the compresser still start up and run?  The refrig. is 4 years old.  Any suggestions? Any help would be greatly appreciated. Mike
  • tarpon22 Apr 28, 2008
    Mike
    Genius:
  • 1,073 Answers
Check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Posted on Apr 28, 2008
I have a KitchenAid KSCS25FKSS00 side-by-side refrigerator. Freezer suddenly began warming and noticed divider between freezer and fridge very hot. Removed back panel and noticed condensor fan was not...
Yes, you need to replace that fan...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
My deep freeze is running non stop ,i have noticed it this weekend after going to get grociers and now it is kinda packed but i have noticed it running all the time why? what should i do?or look for? it is...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 16, 2010 | Frigidaire 14.1 cu. ft. / 399 liter...
Frigidaire FRS23R4CW2 side by side refigerator It is running but it is not cold at all. the fan work I check the back of the refigerator. what is the problem.
Hi, if the condenser fan is up and running at the back, what about the compressor? When the fan is on, the compressor should also be on. Place your hand on top of the compressor, but carefully as it could be very HOT if it is locked up! If it is hot, more then likely the compressor has failed and is off on its overload. If you can hear it click on and off so often, it is stuck and tripping on the overload. Check the condenser coil in back to make sure it has no layer of dust covering the front of the coil. This will cause internal pressures in the system to be very high causing the compressor to stop. Check and make sure the fan in the freezer, evaporator fan is also running. Check what I have asked of you and keep me posted.
Sincerely,
Shastalaker7
Feb 03, 2010 | Frigidaire FRS23R4A Side by Side...
My condensor fan is not running. I looked in the
Hi, Check voltage to the fan. The fan will only run when the compressor is running. If you have voltage to the fan whilr the compressor is running, replace the fan.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 14, 2009 | Frigidaire FRS26R4A Side by Side...
Condenser fan torque question (F'aire side-by-side)
It should not need help getting started and will hurt a little to stop with one finger also it will cause the sides of the frig to get warm maybe even hot around the door try puting a small fan behind the frig with the back panel off till you can replace the fan that will help you know if that is causeing your cooling problem
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
Mar 17, 2009 | Frigidaire Refrigerators
Frigidaire side by side
booster on compressor not condesor, if you needed a "boost" to run compressor sounds like you got bad compressor.
Feb 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Not cooling after smoke damage
Assuming that the motor is running, my best guess would be that the condenser (a large grid of thin piping) was covered in soot, and should be THOUROUGHLY cleaned, preferably with compressed air.... The condenser will either be underneath the unit, behind a small panel in the front bottom of the unit, or at the back behind a cover at the bottom of the fridge which runs the whoile width. Make sure the fan at the back near the compressor is also running....if the condenser fan is not running when the compressor is running, it won't cool. If the condenser is excessively dirty, it won't cool!
Jun 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
536 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
