Question about Westinghouse TX-47F430S 47 in. LCD TV
Tv won't power up
This is my second one and I cant get either to power on at my house. I checked the plugs and they power on other items. Is there any kind of reset switch or something I need to do?
  • bdj66 Apr 28, 2008
    I just had the room added on do you know what voltage i would need?
  • 487 Answers
You need in the states 110-115 V make sure the outlets are grounded and the wires are connected to the right terminals.
Black to the brass screw and not to the silver. White on the silver screw and green or bare to the ground (green or regular) screw
Posted on Apr 28, 2008
  • 558 Answers
You may not have enough voltage at the wall outlet. you need to check to see if your pushing enough electricity for the unit to power up.
Posted on Apr 27, 2008
  • Scott Hill
    Scott Hill Apr 28, 2008
    the tv has a minimum wattage requirement an electrician will be able to tell you if you need to up the circuit breaker in amps but i would recommend a different one than the one who "built" the addition" just to double check his work
  • Scott Hill
    Scott Hill Apr 30, 2008
    I agree with dutchman05 Even though the lcd tvs I have seen will work in a 240 environment hence 110 to 240. the minimum you need for the tv is 110 however if you cant supply the wattage for the tv the tv may simply shut down. easy check carefully move the tv to another location and plug it in and see if it powers up
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
WON TURN ON
For the first step, try using the button on the TV itself.
Secondly, check if the power cord is snug, and not burnt. Sometimes after a blackout, there would be a power surge, and that might burn your plug.
If both doesn't work, the fuse in your TV may be blown, or the Power Supply may also be burnt too. If this happens, you're going to have to hire an expert to help replace the broken parts.
Note that in some TV models, the fuse can be replaced by users. If this is your case, try checking the fuse to see if it's blown or not.
Feb 02, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Gog 2816 satellite reciever, cant tune as i dont know the password. how can i reset it?
Instructions
    • 1 Check the TV and make sure the channel is set to 3 or 4 for the primary TV set, or channel 60 for the UHF (secondary) set, if the receiver is a "dual-mode" device.
    • 2 Check all connections on the back of the receiver. Make sure all cabled connections are tightened and all plugs are securely plugged in.
    • 3 Check for a key card loaded in the card slot on the receiver. If you have a key card, slowly and carefully remove the key card. Leave the card out for at least 30 seconds, and then re-insert the card.
    • 4 Unplug the main power cord from the back of the receiver. Wait at least 30 seconds and then plug the power cord back into the receiver.
    • 5 Press the "Power" button on the front of the receiver to power on the device. Allow the receiver several minutes to acquire a signal and download any additional updates. The receiver is reset.
Read more: How to Reset a Satellite Receiver ' eHow.com http://www.ehow.com/how_2127605_reset-satellite-receiver.html#ixzz2Qyh3yF2m
Apr 18, 2013 | Computers & Internet
I don't have power getting to my tv, we moved house I have plugged into power and then tested another item to ensure the power source works. I have one of those power saver plugs and I have removed th
tried to unplug the tv and don't use for a while to reset the power supply. then re plugged it again and power it on again let see if it works. if still won't power on then the power indicator is blinking you must need to check the power supply board which you need to remove the back cover.
Nov 25, 2012 | Televison & Video
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
Hotpoint Ultima Extra WMA66
something is shorting out direct, remove plug from power supply and test each item, element / pump / main motor etc for down to earth, replace the affected item
Sep 30, 2007 | Washing Machines
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
472 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
