Question about LG VX8300 Cellular Phone
I can't hear you !!!!
I cannot hear or be heard my phone (just out of the blue) and when I try to check the volume setting on the side of my phone, it says "master volume/car kit". I've tried powering it off and on again and also plugging it into the charger. Do you have any other suggestions before I have to take it into to the store because I know there will be a substantial charge for that !!!
  • 1 more comment
  • Anonymous May 05, 2008
    i also had that problem,instead of try plugging in into a house outlet beacause car kit means it got wet
  • blueeyes22 Jun 09, 2008
    I had that same problem from out of no where my phone went into car kit... I think it got wet. I tried a few other options I found on this page and finally just plugging it into my home charger for a second fixed it.
  • Anonymous Jun 15, 2008
    I accidently got my  LG VX8300 wet and after it dried off, I plugged in my home AC charger and the phone went into Car Kit mode.  At the local Verizon store, the technician cleaned the contacts with alcohol and a Q-Tip. But as soon as I turned the phone back on, it was in Car Kit mode. So I went to the Verizon store where I purchased the phone and was told that LG has designed the phone in such a way, that when the phone does get wet, as mine did, it goes into Car Kit mode so that LG knows for sure what the problem is.  Moral to the story is: Don't leave the phone on the kitchen counter when I'm washing the dishes.  Dah... Water splashes and goes everywhere!
  • 31 Answers
Car Kit doesn't necessarily mean the phone got wet, but it does mean that there's a problem with the charging port. Most likely there's a lot of corrosion in there, and if you clean it out then it may get the phone working again.
The best way to clean your charge port is with some contact cleaner and a toothbrush.
If the problem persists after that, then you'll want to bring it in to a store and get the phone serviced or replaced.
Posted on May 06, 2008
When I use Head phone I can hear but other side cant hear me
Have you checked by doing the following:
1) Go to Control Panel->Sounds and audio devices.
2) Click the Audio tab.
3) Under Sound Recording.
4) Click the Volume button.
5) Adjust the Microphone's volume till you can be heard.
Jan 31, 2011 | Computers & Internet
I got a avic z110bt and when i connect my blue tooth to my phone i can be heard but i cant hear who on the line i have reset the unit and i updated the unit
You must adjust the volume on your phone; make a connection with some one using the blue tooth and then try to raise the volume on your phone and also on the car stereo and you'll hear the other person. hope this resolve your problem.
Dec 21, 2010 | Pioneer AVIC-Z1 Car DVD Player
Why did my sound stop working on my LG Vu? I didn't drop it or hurt it. I can't hear or be heard during calls either.
Did you check the setting on the side switch? That will adjust both the ring volume as well as the volume of the speakers.
Normally, I wouldnt expect to find a control for a mic on a phone
Oct 14, 2009 | Cell Phones
I cannot hear calls but they can hear me
Not much to tell you other than putting the factory software back on it. Thats the chance you take when you flash any phone.
Sep 21, 2009 | Palm Treo 500 Centro
The bluetooth headset is on
this s bcoz of volume settings while calling i guess...u better check the volume settings friend!!!
Jul 12, 2009 | Sony Ericsson W910i Cellular Phone
Reseving calls
When u get a call or ur making 1 just tap the screen frm wher u increase ur phone volume....when u do tht u'll get the option 2 increase ur call volume .... peace ... _\m/ .
Apr 10, 2008 | i-mate JAM Pocket PC
W220 hearing problem!
The internal screen settings only adjust volume of ringer, the external button on side adjusts ear piece/hand set volume.
If the volume buttons do not turn up the volume of the hand set then the handset is defective
Mar 27, 2008 | Motorola Mobility W220 Cellular Phone
Can't hear phone ringing
There are many reasons for this to occur, first select a profile and set the ringer to an audible tone and adjust the volume to a lever you can hear clearly. To do this first try pressing the silver button on the left side when the main screen is facing you(Open phone) and if you look closely you'll notice one button on the side has a top and a bottom half the top increases the volume and the bottom decreases the volume. If the volume it up all the way and you still hear nothing then press the menu button and go to settings, followed by going to sounds and select the profile "normal" and adjust as necessary to make your ringer alert you, if the tone is not heard try a different one, if all else fails remove the battery and leave it out for two minutes, then put it back in and turn your phone back on. This sometimes is necessay to make a newer phone clear a "bug" as newer phones are much like MS Windows and require a re-boot from time to time. I hope this helps...
Nov 22, 2007 | Motorola Mobility RAZR V3
Can't hear the Ring
Hello, Push the center button(in the middle of the four directional arrows). Scroll over to the screwdriver/wrench icon and select it. Scroll down to the "Audio" line and select it. Scroll down to "Loud Detail" and select it. Set "Ring Volume" to a higher number(I use 7). Have someone call you and you should be set. If this doesn't work, with the phone open, look at the two buttons on the left side of the phone, push the top button until you have your desired ring volume. Good luck!
Jul 26, 2007 | Motorola Mobility V710
LG VX8300 Cellular Phone Logo
147 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
