Question about LG Refrigerators
LG Model # LRDN22711TT Leaks on floor after ice accumulates and melts on freezer base (Bottom Freezer)
mgprice
  • 744 Answers
SOURCE: Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 14, 2009
Testimonial: "Greatly appreciate yor help, Mike. Found screws to remove back panel, but the ice maker is plugged into a hole in panel can this be unplugged?"
  • 219 Answers
SOURCE: water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Posted on Mar 19, 2009
  • 358 Answers
SOURCE: water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Posted on Apr 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Posted on Jul 01, 2009
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Water accumulates in the bottom of the freezer, model FRS26ZRG, then melts out onto the floor
the water drain is clogged, when a freezer goes in to a defrosting cycle it MELTS the excessive ice build up and the water drains throug a drain (usually in the back of the freezer) than goes in to a pan under the freezer to evaporate until the next defrosting cycle, so check the pan if it's not full of dust or debrie (cat toy HA!) as well...
Cheers!
Aug 31, 2011 | Blenders
My LG LRFC25750WW refrigerator collects water in the bottom of the freezer (bottom freezer) that freezes, then leaks over the floor.
This is a known problem. There is a drain that allows condensation to escape to the bottom of the unit where it will evaporate. Ice accumulates in the drain causing it to clog and the moisture drains to the freezer bottom.
The solution is to empty the unit and defrost it for 24-36 hours. The ice in the drain will melt allowing the unit to work as it was designed. To avoid future problems make sure the doors are always kept shut. Ours clogged after our son left the refrigerator door open on day.
Jul 15, 2010 | LG LRFD25850 French Door Refrigerator
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
WATER LEAKING OUT OF FREEZER DOOR
The defrost drain hole in the bottom of the freezer has frozen over. Turn off the fridge. Remove the shelves and bins. Remove the rear panel of the freezer. You will see ice on the bottom rear of the freezer. Use a hair dryer to melt the ice,especially in the drain hole once you get through the surface ice. Once the drain hole is clear,pour a cup of hot water through the drain hole followed by 1/4 cup bleach. Re-install your parts and turn the fridge back on.
Sep 21, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Dec 11, 2008 | Samsung RS2630WW Side by Side Refrigerator
Water leaks
I have the same problem- had service man out & he replaced the ice maker- not a cheap fix, especially since the ice continues to accumulate at the bottom, then melt onto the floor.  no good answer yet---
Apr 20, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
301 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
