Adapter problem--compact wirel
No signal
  • Kevin Flannagan
    Kevin Flannagan May 11, 2010
    Ethernet signal, wireless signal???? Some detail will help.
I have tata internet connection. i inserted two ethernet cards in server system. when i was going to use ping command for internet connection, "DNS server host not reatchable" message coming. ping command working & and also browsing after one of the ethernet card disable.
i want to connect the systems on LAN for internet from server. please suggest for this problem.
Posted on Apr 30, 2008
Wireles adapter radio off
Look on both sides and the front of the computer for the wireless switch to turn it on.
After you turn the switch on there are keystrokes that can also toggle the wireless on or off. Normally you Press and Hold the FN function key located at the lower left portion of your keyboard, then hit the correct (F1 thru F12) key that toggles the wireless. The correct key to hit will have the icon of a wireless signal ))) or it will have the icon of a tower with the wireless signal ))).
Apr 24, 2012 | Dell Inspiron 1501 Notebook
Wireless does not always work - signal too weak
Assuming Windows OS, go to "Device Manager", double-click the wireles adapter, then select the "Power Management" tab, uncheck the "Allow computer to turn off .. etc." and press OK
I hope this helps,
Majdi
Dec 27, 2011 | Computers & Internet
Hi, i have a D-link DWL-G122 wirelesss adapter and when connected after 30 min or less the conection gets lost , what to do?
You will need to contact your ISP - they know your set up - it is all sent to them and they do not care for it - - most likely the ISP you have needs to be told to keep the signal stronger - also you can go into your unit and set a STAY ALIVE setting - please read your wireles ROUTER - it is the signal sending unit - or wireless rounter that is the problem - not the adaptor.
May 07, 2010 | D-Link AirPlus G DWL-G122 802.11g/b...
Wireless routher will not connect to my computer wirelessly. If plugged in with ethernet cord, internet works fine.
make sure that your computer's wireless adapter is turned on. usually laptop computer came with wireless switch on the side or infront of the laptop. you can also enable the wireles adapter of your laptop by pressing Fn key + F5 or F6 depends on the laptop brand. just look into the F keys with computer picture and signal in it.
Apr 04, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Cant get wireles signal, i just switched service providers and can not pick up wireless signal.
Do a channel scan before you call provider and ask them to change it to a channel number that is not being occupied. Ask you provider to change your channel number on your router? You and your neighbor is sharing the same channel number. One is over powering the other.
Dec 09, 2009 | Linksys Wireless-G WGA54G 802.11g/b...
Can not connect to the internet thru a wireles D-link WUA 2340.
Hi Antonio, you need to make sure your routers wireless settings match the settings of the computers wireless adaptor. Both need to be exactly the same.
Jun 02, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
Need a stronger signal for the wireles in our house
Your better off getting a repeater for your wireless and strategically place it in a room where it can amplify to the next and so on. Concrete is virtually impossible to pass through with the signals wireless transmit so a repeater strategically placed is the best way in my opinion.
Jan 30, 2009 | 2wire (1000-100016-002) Wireless Adapter
Signal strenth
Ok, since im figuring these are fairly new products, you should call Linksys, concidering you are still under warranty. If I were to make a guess, maybe you needed to forward or open a port on the router to allow signal to flow between the two.
Dec 28, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Good Signal, Good Speed, Slow Internet?
Try plugging the computer straight to the router.If all is well the adapter may need a firmware or driver update.Or your adapter may be experiencing some type of heat problem or failingRICHARDM69
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Sometimes wireles goes down unexpectly
OK often it's the XP Zero Configuration service, try disabling that and it may be better... also get the latest driver updates... Often just to disable and re-enable the wifi adapter sometimes in network connections, brings it back without a reboot too.
Jul 08, 2007 | Zyxel ZyAIR G-1000 802.11g/b (zyairg1000)...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
