Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony KP-51WS510 My red will NOT line up with the others, it just keeps jumping around... Flash focus doesn't help either..
  • Anonymous May 05, 2008
    Red Shadows of images appear. No clarity anymore. Flash Focus won't adjust it. Won't let me do it manually. I can move red up & down but not right to left
  • 121 Answers
You need to replace both convergenceIC's STK392-560 you can get them at the sight I posted at bottom plus picture installation instructions as well as free online tech support if you need while you are doing your repair remember you need to replace both of them
http://servicemanuals.vstore.ca/
Posted on Apr 27, 2008
Sony kp-51ws510 Rear Projection HDTV - Picture quality is fine, just doesn't have any red's in the picture. What shoud i look into?
Make sure the cable box or DVD/Blu Ray player is hooked up properly. Sometimes one of the component cables can become loose and lose the reds.
The red tube could be shot also. My old projection tv had the green go out. Believe it or not the whole thing can be replaced, but to replace a CRT on an older model can cost a lot.
May 18, 2012 | Sony KP-51WS510 51" Rear Projection...
Unable to flash focus, red curved lines at the top of screen, manual convergance will not work, problem started after a lightning storm with power surge
Ur tv now,totally have dead parts,on the tv convergence board.That,why ur flash foucus or manual covergence alignment R,G,B colors line will not matches up.The convergence board parts 2 STK convergence ICS and some or all it resistors,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-51WS510 51" Rear Projection...
04 sony 56 inch convergance
Convergence has failed. The Sony type 1 convergence repair kit from www.tvrepairworld.com covers your model. The kit contains the parts and the CD with instructions.
Dec 12, 2009 | Sony KP-51WS510 51" Rear Projection...
Have a Sony KP-51WS510 with red outlines
In replacing the CRTs, there are multiple focus adjustments. The basic one first is the Mechanical lens adjustment on the CRTs, (in this case red), the second one is the Electronic Focus on the Screen/Focus Block on the front of the unit behind the front panel. The third focus and on of the most important is the Beam Centering Focus. (In this case RED CTR) It is located on the neck of the CRTs. They are the first set of adjustment rings up from the CRT Boards. If any of these focus adjustments are off they will cause a symptom like yours to occur. Normally these adjustments are made before any convergence adjustments are made. I would double check to see if the repairman made these adjustments.
I hope this helps
Skyassoc
Jun 29, 2009 | Televison & Video
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
Red lines around images--Sony Kp-51ws510
There are two chips behind the large heat sink that need to be replaced. Also, depending on how the chip(s) failed, the fuses should be checked as well. They are very small, wired in, and right below the heat sink on the side nearest the back of the tv. There are 4 and they are brown in color. Can you unsolder and solder in the new chips? The cost for parts would be around $40.00.
Apr 12, 2008 | Sony KP-51WS510 51" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
