SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
SOURCE: model 110 washer will not go into a final high speed spin.
is it top load or front loader kenmore what
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
SOURCE: Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
SOURCE: clothes seem too wet after final spin
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
