Sony KP-57WS510 57 in. Rear Projection HDTV Television
Problem for Sony KP-57WS510 57 in. Rear Projection HDTV Television
Sony rear projection TV
By Larrystatkus on Apr 27, 2008
Unless I'm going crazy, (a possibility) I've noticed that my picture is significantly dimmer.
I've tried changing the "pic mode" and it still seems not quite as bright.
I was wondering if there is a way to check it for sure, or to reset it somehow.
Thanks!
Larry Statkus
larrystatkus@yahoo.com
Same Problem
May 12, 2008
-   Larry, I don't think you're going crazy. If you are you're in good company. I have noticed that my Sony (I don't know the model #, but it's a 60 inch rear projection HDTV) has been quite a bit dimmer. I tried to adjust the brightness, but it was already maxed out. I hope someone answers your question soon, because I'm hoping there is an easy solution (there never is) to fix this problem. I love my TV.-   Guest
Solution #1
posted on Jun 15, 2008
Somewhat Helpful)
slayer1
Rank: Guru  Sony Expert
Rating: 86%, 50 votes
If your tv uses a lamp then change the lamp
Was this helpful?
Yes
No
Solution #2
posted on Sep 08, 2009
Not Rated)
phunny_96
Rank: Apprentice
Rating: 0%, 0 votes
no more than likely your lamps are just dirty. take the back of and wipe them clean with a clean clothe. THen if the problem persists you are looking at a lamp issue. but try and clean first.( I had the same problem.)
Was this helpful?
Yes
No
Popular Solutions for Sony KP-57WS510 57 in. Rear
Questions and Unsolved Problems for Sony KP-57WS510 57 in. Rear
Do you recommend Sony KP-57WS510 57 in. Rear Projection HDTV Television?
Answer
Answer
When the set is turned on i can hear the relays engage and thats it red led flashes 6 times
Answer
my kp46wt510 has a red shadow to the right side of any image. Also the convergence mode will not... (More)
Answer
hi, i have a 60 inch projection sony tv, from circa 2000, tv is fine but it seems as though the... (More)
Answer
tv will not come on the red light blinks and you get volume no picture then it shuts off
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
