Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony Model KP-51WS510 Issue
Hi I am having the same problem "Suddenly while playin my ps3 (Wii) the left half and the far right few inches of the screen had a red duplicate image coming off of everything gradually separating from whatever image is on screen more as you reach the edges of the screen. Sorry that was a huge run on sentence. I was able to slightly fix the problem through the convergence setting but am not able to move it enough. I've been told a light is out? I don't know... Please help... Anything..." Does this work? Do you only need to purchase 1 Convergence IC? Where do I get the installation instructions?
  • Sony Master
  • 8,617 Answers
You will need to replace both convergence ICs STK392-560 you can get replacements at the following link and the give free instalation instructions plus free online tech support if you need help installing them. Here is the link.
http://servicemanuals.vstore.ca/
Posted on May 03, 2008
The picture is is now in pink
If Sony KP-51ws510 it is an common issue with the picture tubes but there may be a simple way to adjust something in the set to correct this--these had problems with the 3 picture tubes where it can go to excessive red, green or blue.
Confirm model and issue and I will assist.
It only requires a screwdriver and the back does not have to be removed in this case.
Mar 20, 2012 | Sony KP-51WS510 51" Rear Projection...
Convergence chip part# ?
Convergence chip used in Sony KP-51WS510 part number is as follows..
STK392-560 and Sony part number, 874901908
Available in Part Store.
Thanks.
Dec 26, 2009 | Sony KP-51WS510 51" Rear Projection...
I have the same problem. Please advise how to fix it.
my sony kp-51ws510 is out of alignment and the colors are in 3d
Dec 09, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-FX43M31
On the Sony FX43 100Hz 43-inch rear projection TV, three flashes indicates an Over Voltage Protection problem, occurring in one of the power supply circuits T603 or R672.
The fix will most likely cost more than the set is worth second-hand, I'm afraid.
Jun 28, 2008 | Sony KP-51WS510 51" Rear Projection...
Kp-51ws510 red shadow convergence...
you need to replace your convergence ic's STK392-560's they both need replacing I will post a link where you can get the ic's and picture installation instructions as well as free online tech support should take about 45mins to repair if you do it yourself and save you alot of money
Apr 26, 2008 | Sony KP-51WS510 51" Rear Projection...
PS3 to Sony KP-51WS510
To connect a PS3 for the best picture possibe is definitely HDMI. It carries both audio and video in the highest quality possible.
Apr 17, 2008 | Sony KP-51WS510 51" Rear Projection...
Blue spot
the model number KP-51WS510 deosnt use a bulb or lamp. and touching the face of the lamp will not cause color problems in the picture. if your tv is an LCD projection then i would suspect the optical engine as the culprit. to check when you turn the tv off do you still see the blue distortion? if so then you have a bad optical engine.......as long as it is an LCD projection.
Apr 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-51ws510 51" rear
The picture tubes are on there way out. turning down the screen control inside the tv sometimes gets a little more time out of it
Feb 16, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
