Question about HTC S620 Smartphone
Pulling htc s620 battery soft reset
How do i pull the battery soft reset. thank you
  • Anonymous Apr 06, 2009
    When I switch on my HTC S620 it gets so far and then stops. Can't switch it off using the on/off button. I have tried removing and replacing the battery, but the problem remains. Any ideas?
You can do this:
- remove the battery
- press at the same time the soft keys (the 2 keys just under the screen with the symbol "-"), and do not release
- replace the battery
- always press the soft keys, press the power button (5 seconds)
- release power button
- release the soft keys
- s620 will not start windows, but open a black window
- press the send key (green telephone) to restore factory default configuration.
- s620 will enter in windows and work normally.
good luck
Posted on May 23, 2009
I dony have htc s620 pc suite?i wanna to connect my phne to p.c nd save my contact nd instal new window on myphone
Posted on Dec 15, 2011
I think that is basically it. Remove the battery then replace and power up. It doesn't work though. Can't even do a factory reset. I did manage to get the phone to work properly though just by constantly removing the battery and powering up. Thing is, the battery died and now i'm back at square one. :(
Posted on Jun 22, 2008
After the battery run empty on my HTC S620 mobile, I cann't turn it on (off course the battery now is charged).
Take out the battery, then take out the sim card and the storage card for about a minute hen put back the battery in just the battery. Pushed the power button and then push both of the soft keys, which the keys above home key and the back key, then check if that will power ON the unit if it does you can power it off and put the sim card and memory back in.
But if still same problem I will advice you to try a different battery just to check if the battery is bad or something more is causing the problem.
Jul 29, 2010 | HTC S620 Smartphone
HTC s620 freezes with incoming texts
I suggest take it to a service center store that deals with your service carrier and request to have it flashed. Keep in mind that you have to backup all of your info in that phone since the "flash" is going to delete it all. Good luck.
Jan 03, 2010 | HTC S620 Smartphone
I have a bt htc s620 lost all drivers..can u help to find the drivers
All drivers will be restored if you perform a "hard reset".
NB. not a normal soft reset.
Mike
Oct 30, 2009 | HTC S620 Smartphone
The voume is too low on my HTc 5620 its set to the highest setting , calls coming in are very quite
install registry editor in htc and open HKLM/SOFTWARES/HTC/AUDIOGAIN and change the EAC_GAIN_HEADSET value from 67 to 70 and apply soft reset.
Sep 06, 2009 | HTC S620 Smartphone
My htc phone got stuck on WINDOWS MOBILE screen. it wont do anything, not even turn off. ive taken out the battery and turn back on, still same thing. what can i do?
Hello, These methods have been confirmed on my phone with both T-Mobile's ROM and Excalibur (S620 original ROM)
Turn the hand-held off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
Let us know if you have any other questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Apr 18, 2009 | HTC S620 Smartphone
Would like to know how to hard reset
remove battery for more than 15 sec
Apr 10, 2009 | HTC S620 Smartphone
Reset default on a HTC S620 T-mobile phone (known as the DASH)
turn it off, pull the battery, and as you put the battery back in, hold both soft keys down while its powering on. Then release the two soft keys, and it will give you an option to reset all data.
Jan 14, 2009 | Motorola Mobility RAZR V3
Htc s620 instuction manual
Hey you can get the manual from here
http://www.htc.com/europe/FAQ_Detail.aspx?p_id=2&act=um
If you need more asistance, let me know. Good luck.
Mar 29, 2008 | HTC S620 Smartphone
My HTC S620 stays on second start screen
Hello, These methods have been confirmed on my phone with both T-Mobile's ROM and Excalibur (S620 original ROM) Remove any memory cards before starting this process.
With OS:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
Without OS:
Nov 28, 2007 | HTC S620 Smartphone
HTC S620 Smartphone Logo
2,608 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
