Question about Palm Tungsten E2 Handheld
Areas of screen not responding to touch
I have an tungsten E2 and after just 3 months I am now all of a sudden having troulble with some areas of the screen not responding to touch this is very annoying, i have done a soft and hard reset but nothing worked? is there anything else I can do?
  • 4 more comments
  • nickxyz May 05, 2008
    E2 not respond after hard reset. touchscreen not sensitive
  • DedicatedPDA Jun 15, 2008
    My Tungsten e2 fully charges but screen does not work at all to get past the digitizer screen anymore. Dischaged battery and then did a full recharged again thinking it was just the battery. Cannot even get pass the digitizer screen because tapping anywhere on the screen does not work at all. The Power on/ off button, and tapping reset tap works but that's all. Please help as this was a brand new PDA and worked for a year and charges on the Tungsten e2 cradle but is useless now since the digitizer screen.
  • AShone Jun 29, 2008
    Same problem. the bottom 60% of the stylus operated screen is unusable.
    The buttons at the top function normally, the top 40% of the screen seems ok.
    Haven't dropped it or anything... I was working on a simple spreadsheet and the thing suddenly locked up. When I did a Reset, the above symptoms kicked in. Do I need to reload the OS? (is this possible?), or is it a hardware problem?
    I've tried the reset numerous times. I've let it rest for a couple of days, then come back to it. At one point I was able to use the stylus writing application (with limited success) but this function has now ceased to operate. It is really not usable in this state; any advice would be very much appreciated.
  • marywyrsch Jul 13, 2008
    My handheld will not respond to the stylus. It is hard to turn off and on. Is this a battery issue, or just an age issue. It is four years old.
  • ralpheeus Jan 03, 2009
    M;y problem is that my keyboard on my E2 stoipped writing and I only get,,,,, dots. Help if you can
    Ralpheeus at
    Grits2@roadrunner.com
  • bob collins
    bob collins May 11, 2010
    Has this been resolved?
    Novelist:
  • 164 Answers
The digitizer is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
Posted on Jul 25, 2009
Unresponsive touch screen on Palm Tungsten E, buttons work
Often the problem on these is contamination that gets under the edge of the escutcheon which effectively presses the screen out of the usable area preventing entry in the normal area.
Using special screw driver (very small TORX) remove the covers and clean the screen edges. Note one has to gently pry the cover off when ALL screws are out.
A "sometimes works" method is to run a piece of paper or thin cardstock around UNDERNEATH the rim of the escutcheon to clean the contamination.
Note, you MAY need to "recalibrate" the screen after these procedures.
Jul 27, 2010 | Palm Tungsten E2 Handheld
Touch screen kc910 renoir
its the touch probs.... if ur cell is preety new. i mean bot b4 2-3 months then ask 4a replacement in ur service station.. better fight... or service it 4 free usin ur warranty
Apr 11, 2010 | LG KC910 Renoir Cell Phone
I have a tungsten E2 and rep;aced the battery, after charging it overnight and doing a soft reset I am only getting the start up screen asking for password. On the screen are the number pad,...
Still not working, decided to purchase a new one for mine was 3 years old and it was not worth investing a lot of money to fix it.
Thank you for your help............snicksandsam
Oct 15, 2009 | Palm Tungsten E2 Handheld
Palm Tungsten E2
Try the hard reset procedure.
If still is failing, then the digitizer is defective and needs to be replaced.
Best regards,
May 17, 2009 | Palm Tungsten E2 Handheld
Palm tungsten E2 touch screen unresponsive
I noticed this problem with mine and solved it by loosening the 4(four) T5 screws in the back. The problem is caused by a swollen battery. When the PDA is left charging for extensive periods of time, as mine was(several months of inactivity and never thought to unplug it), the battery will swell. It's still a good battery and holds a charge, but the increased girth presses on the internal boards of the PDA causing the screen to register a continuous "touch" and therefore seems locked. It's actually waiting for the phantom touch to release so it can act. Unscrewing the fasteners allows the body to expand, thereby releasing the pressure on the screen and letting the phantom touch go away. I'm going to see how well my e2 does without the screws in it at all for a few days. The front and back panels have "clips" molded into them which hold to the side frames, keeping it closed. But the fasteners are there to ensure the PDA doesn't fall apart all together. So, wish me luck. I'll report back in a few days and update this.
Oct 25, 2008 | Palm Tungsten E2 Handheld
Touch screen problem
The top transparent digitizer is defective and needs to be replaced.
Best regards,
May 08, 2008 | Palm Tungsten T2 Handheld
My touch screen is no longer working on my Tungsten E2
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult.
Best regards,
May 08, 2008 | Palm Tungsten E2 Handheld
Mal functioning
Has this been fixed?
Mar 06, 2008 | Palm Tungsten E2 Handheld
Touchscreen/Writing Area problem - Tungsten E2
keep recalibrating touch screen in different spots till you find one that works
Feb 27, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Alm one
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Tungsten E2.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Oct 21, 2007 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
146 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
