Question about Canon imagePROGRAF W8200 InkJet Printer
Printhead error "no error code number" turn power off.
For this problem did you mean replacing the print head or the whole print head assembly.l took out the printhead and it till gave me the same error warning. l thought it might have given a replace print head warning.
  • 1 more comment
  • laithsaour Oct 26, 2008
    when the plotter intialized I got the message "print head error towrn the power off" and it stopped doing anything even head cleaning I am looking for soltuition to my problem.
  • Anonymous Oct 27, 2008
    i have the same problem
  • artalex Jan 13, 2009
    A have the same problem with my Canon W8200 PG. It is out of order with "PRINT HEAD ERROR" and then "TURN OFF"
You need to enter a service mode before the error message pops up. hold down paper source button + online.
that should override the message before it pops up.
go to replace print head selection. or do a clean. it may still be working. let me know if this doesn't work....but at least you can still get past the message now! marty
Posted on Dec 27, 2010
  • 121 Answers
Yeah...I meant the whole printhead assembly.
Posted on May 26, 2008
Error light flashes 5 times. How do I fix the problem?
According to the manual (see
" Five flashes: Print Head is not installed. / Print Head is defective."
"Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it.
If the error is still not resolved, the Print Head may be damaged. Contact your Canon Service representative. "
May 12, 2014 | Canon PIXMA iP3500 Printer
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
What does an error 5200 mean?
(1) With the printer turned on, unplug it
(2)Open the top and bring the ink cartridge holder to the middle
(3)Raise the gray bar and remove the print head assembly with the cartridges in it
(4) Lower the gray bar with the head missing and close the top with the head out
(5) Restore the power,wait til the printer wakes up
(6) It will tell you to put in the cartridges
(7) Restore the print head, close the top and the printer should resume working.....
it is a printer head error and some solved it that way ..after you do that it will resume the function and work ..
Jun 01, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Got "wrong cartridge" error while attempting to print. Removed & reset all ink cartridges, still same error. Removed inks & print head, immediately lost power. Unplugged, waited, put everything...
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Phaser 8400 Error Code 07.009.42:265696
Hi carlt322:
Here is your problem.
The printhead is tilted back but not in the park arms and restrained properly. This is due
to the wiper assembly not moving up far enough for the park arms to hold it.
1. Check the printhead heater wiring.
2. Check for an obstruction or damage in the process
gearbox. Ensure the gears are correctly aligned and
homed, see page 6-8. If faulty replace the process
gearbox assembly.
3. Run the Head Maintenance Clutch test, if it fails replace
the clutch.
4. Run the Wiper Drive test. If the test fails, inspect the
maintenance drive system.
5. Replace the exit assembly.
Hope this helps
Sep 25, 2009 | Xerox Phaser 8400 Laser Printer
Error: print head not installed. Install print head
Make sure the contacts on the carriage assy. where the printhead sits are clean also. If your printer is still under warranty it will be repaired free of charge, if not, it sounds like you may need a new printhead. The part number for the printhead is printed on one side, it's always a qy6- number followed by 2 sets of 3 numbers each.
Jun 22, 2009 | Canon PIXMA MP610 InkJet Printer
Error msg says "COLD PRINT HEAD"
1. The Printhead/Controller
cable assembly is
2. The environment is too cold
for the printhead to sustain
operating temperature.
1. Make sure the printhead/
controller cable assembly is
connected to J401 at the
printhead and J6 on the
controller PCBA.
2. Move the printer to a
warmer location.
If none of this works you might have a bad printhead. The thermistor on the printhead has gone bad and needs to be replaced.
Please contact me if a printhead is needed or if you have any other questions. I am also an ASR for Printronix meaning I can supply you with new and used parts and printers.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
May 16, 2009 | Printronix T5000 Thermal Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
After I took out PrintHead and tried to clean it up again, I put it back in with Ink Cartridges and got error code 3813 - also couldn't fix it. Removed Ink Cartridges, turned printer off. Turn back on and it will forget about error code 3813 and will tell you to install Ink cartridges. Do that and error code 3813 is gone and ready to print.
A note: I did not find anything telling me I have to change printhead but my problem with black ink printing still exists so I will get new printhead and see if that problem gets fixed.
Sep 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
in the printhead assembly or the
mirror motor cable to the engine
board cable or engine board
the mirror motor cable connected to
J3 on the engine board. If incorrect,
J3-7 measures approximately
engine board. If correct, replace the
engine board
printhead assembly
Jun 19, 2008 | Lexmark Office Equipment & Supplies
Canon imagePROGRAF W8200 InkJet Printer Logo
889 people viewed this question
old marine
old marine
