Onkyo receiver my onkyo receiver lately has been cutting out. The sound comes on and the I hear a click and the sounds goes off. This will happen several times and then the sound stops completely. It is a Onkyo Quartz, synthesized tuner amplifier.
  • 4 more comments
  • marylouise Apr 27, 2008
    probably for about 10yrs.
    I would have a "Pro" do the repairs. Do you think it's worth have it repaired? We haven't had any problems with it until now.
    So, if I disconnect the speakers how will I know if that solves the problem. I won't be able to hear anything, will I?
    would you answer my last question, please. Regarding disconnecting the speakers.
    thanks mary
  • marylouise Apr 28, 2008
    I see. Can I get back to you later on this? I will try the speaker thing.
    thanks
    mary
    My son also determined that it wasn't the speakers. But I thought I would see what the experts said before I took it somewhere.
    I will get back to you on this later in the week. Will you be available?
    mary
    Genius:
  • 3,587 Answers
That means that your amp is taking its sweet time going completely down the tubes(so to speak)...had it for a while?
Posted on Apr 27, 2008
  • 5 more comments
  • Patrick Michaels
    Patrick Michaels Apr 27, 2008
    long time good sound, eh? well...what you are experiencing is a pre failure mode..did you plan on doing the tech yourself, or having a pro do it?
  • Patrick Michaels
    try it with only one set of speakers, and see if maybe it's a load issue..in fact, disconnect all the speakers, and see if it's still doing it.
  • Patrick Michaels
    well..based on a cost value estimate, most likely not..parts will be a major issue..
  • Patrick Michaels
    thankya for using fixya..donate it to a local computer or audio club..they'll love it..
  • Patrick Michaels
    just the clicking from inside the amp..I'm trying to isolate the problem to the amplifier
  • Patrick Michaels
    thought I did..I'd like the speakers off the circuit to determine if the clicking and shut down is from the amplifier end, or caused by a possible blown or near blown speaker element. both can cause that .
  • Patrick Michaels
    Patrick Michaels Apr 28, 2008
    sure...later this weekend? or during the week..
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
I have an Onkyo TX SR505 receiver which for some reason, while watching TV or listening to music, there will be a click heard in the speakers and the sound will be gone. I'll shut off the receiver and turn...
It's probably self-protecting from heat build-up.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 19, 2011 | Onkyo TX-SR505 Receiver
I have an ONKYO HT-S3305 which transiently 'cuts-out' the sound - lasting only seconds (hooked up to TV/satellite HD receiver) Seems to start after about 1-2 hours after switching on. Not the signal...
It sounds to me that some part of the circuit possibly an IC is overheating after several hours and develops a fault.
This will be a very tricky thing to track down. So maybe best to take it to an authorised service agent.
Oct 15, 2017 | Onkyo HT-S3100 Receiver
When I turn on my Onkyo DTR7 receiver, I donot get any sound at the speakers. Normally there is a click, when I turn it on, but I no longer hear that sound. occassionally it will work, if I turn it on...
You must re-seat the HDMI board on and try. sometimes the connections come loose and causes the connection to the Relay trigger not to work.
Feb 09, 2011 | Onkyo DTR7 Receiver
No sound coming out of speakers something is wrong with the receiver
check if it goes to protection mode on power on. see to it that speaker selector switch is set.
Is your speakers connected properly?
Is your music source ok?
Do you hear a click after you switch on the power? the click indicates that the time-on delay transfers the amps output to the speakers which prevents thumps going out to the speakers.
Once it goes to protection mode you need to have it serviced. This is due to a fault in one of the amps and that it protect the speakers from further damage.
Aug 17, 2009 | Onkyo TX-SR502 Receiver
No sound output
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Apr 11, 2009 | Onkyo TX-DS575 Receiver
Sound not coming out of speakers
Mar 15, 2009 | Onkyo TX-DS575 Receiver
Sound cutting out
sounds like the tape monitor may be turned on. First place to check anyways. If it is not the problem, I am happy to talk more about it with you and do some more diagnoses.
regards
Graeme
Feb 14, 2008 | Onkyo TX-8211 Receiver
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
172 people viewed this question
 Grubhead
Grubhead
