Question about Lands Phones
Our phone lines are not working - Lands Phones
  • in_love_and_ Mar 01, 2009
    I have changed phone lines and jacks and still when I pick up the hand set and turn it on I have no dial tone. Is that the problem your having as well?
Line in use
Posted on Jun 04, 2008
No dial tone
indicates that the phones are faulty
the land line carries adsl and phone at different frequencies so as the internet is working so the land line is good
check that the internet and phone line is connected into the correct sockets on the line splitter before the land line connection
Nov 21, 2017 | Lands Phones
Line 2 not working
Do you actually have two lines to the room? Check to make sure all phone cords have four contacts.
Nov 28, 2013 | Uniden TCX905 Cordless Accessory Handset...
I have a Lucent 18D in the office and all the lines are working except line 3 of one of the phones. All the other phones and lines in the office are working. I've made sure everything is plugged i
Sounds like the line 3 button on that set is programmed as something else. When you press feature 00 and the line 3 button what does the programming say on the screen?
Feb 22, 2012 | Lucent PARTNER18 Corded Phone
We have a 4-line system in our office, but it is not working properly. For instant, when line 4 rings...it only comes into one of the phones. All lines are working properly with dial tones. If we would...
Now here's a conflict. Does line 4 work on any other phone where it doesn't ring? You say all lines are working properly wiith dial tones, tnen you say you can't pick it up from another phone.
I don't think these phones have "private lines", but the dial tone comes from the 2nd RJ-14 jack on the wall. On every phone, you could swap the plugs so that line 1 comes into line 3 and line 3 comes into line 1 (you'll lose the intercom) and see if you get dial tone on line 2 which will be the phone that works line 4. The point being to determine if you have a wiring issue or a programming problem.
Carl
Mar 21, 2011 | RCA 25423RE1 Phone
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Pluged in my phone line and the phone reads Error
Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
Apr 09, 2009 | General Electric RCA-25424RE1 4-Line...
Having phone line error
Disconnect the phone line and put a phone on it. If it doesn't work on the phone, go to where the phone line goes into the house and see if the phone works there. If it does not work there call the phone company and tell them you phone line doesn't work.
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
Base unit line 1 is flashing no dial tone
We followed your instructions and are not sure what worked, however, this AM phone line is working.
Sep 30, 2008 | Uniden Cordless phone EXS9950
Phone connection for Lucent 854
You can get a splitter for it which will then divide that one phone jack into 3 out or 4 out which ever you need. the only problem that you might run into is how close the phones might be to each other. Otherwise there isn't much other ways around it with only one phone jack.
Mar 31, 2008 | Lands Phones
Lands Phones Logo
57 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
