I recently washed my Honeywell Type F50 cells and now when I turn on the heater, the "check" light stays lit and there is a continueos clicking sound.
  • billatmcs Apr 27, 2008
    Basically I have always hosed them off to remove the dirt buildup.
  • 3,037 Answers
Yes, washing the cells is basically the only thing you are suppose to do to keep up with maintenance.
well, the check light indicates service, adjustment needed, or cell washing is long overdue. Since you just washed the cells, possibly they did not get put back in right or something is probably wrong with them, try running without them in and see if the light goes off, if it does, then they are definitely the problem
Posted on Apr 27, 2008
  • 758 Answers
You may have damage a cell and also you might damage a plate...Check this website for more details
http://www.townandcountryhvac.com/honeywell/F50_air_cleaner_faqs.htm
I hope this helps
Please rate accordingly
Thank you
Computerrep
    Genius:
  • 3,587 Answers
Washed them? how? i did not know that you were supposed to do that..can you describe what you did more specifically?
Is there a pilot setting on my Honeywell gas valve for a Laars series 2 gas heater for my spa 175N
yes look at gas valve turn to pilot hold down for about a minute then light pilot generator keep holding button down for about 2 minutes then turn to on should stay lit if not need new pilot generator
Dec 06, 2014 | Pool & Spa
Fan shuts off after about 15 seconds of heat..
it don't come on at all when u turn the heater on
Dec 26, 2013 | Honeywell Heating & Cooling
Honeywell smartvalve flashing 6 times, pilot lit but burners won't light
Smatvalves of certain year were bad, check the module and see if its a bad one recalled, if not see the codes youmention for the brand its on.
Oct 29, 2012 | Sterling Heating & Cooling
The pilot will not stay lit on my GWN20T. Have tried cleaning with compressed air. Would this be the thermocouple? If so can I replace with a universal unit? Lowes has a Honeywell 24' for a 30millivolt....
if the pilot stays lit while you hold down the nob and goes out when you let up on it then you need to replace the thermocoulpe and yes thye honeywell will work.
Nov 27, 2009 | Desa International GWN20T Heater
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
F50 air cleaner cells inoperative
Check for any of the metal layers in the cell to be touching or too close together. These units are very expensive to repair and to be honest the best option is to find a disposable box filter that will fill the hole.
May 01, 2009 | Honeywell Air Purifiers
Pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Dec 08, 2008 | Honeywell Electronic Programmable...
I have a Honeywell Electronic AIR Cleaner model F50 F1099 and 2 of the nine wireson the right side of the cell broke while washing the unit. Can we obtain replacement wires?
yes, we have them in stock.  you can email TJ@BoanHeating-Cooling.com, he's our parts manager, he can get you the cost and availabilty of them. Chris
Dec 02, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
