Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dishwasher Hello, my dishwasher is dead no power no lights, I'm thinking a fuse or switch. It's a dial type thats around12 years old......ANY IDEAS PLEASE HELP MY WIFE IS GOING NUTS gEORGE
    President:
  • Whirlpool Master
  • 2,651 Answers
If you have a "dial type" timer, chances are there are no internal fuses, i would start twith the obvious, make sure the breakers are not tripped and after that i would check for 110v at he connection behind the lower acess panel of the unit itself( sometimes a loose connection will burn off a wire nut and leave you disconnected).. if those both check ok sounds as if you might have a bad door latch/switch, not recognizing hte door being closed so not operatin,a few screws around perimter of the door will drop the consloe givin gou acess to check the switches
Posted on Apr 29, 2008
Power comes in to dishwasher but none of the lights come on and dishwasher will not operate
Hello
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Aug 20, 2011 | Whirlpool Dishwashers
No front panel lights Whirlpool GU2500XTPB1. Power to dishwash is good.
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it (ZERO OHMS) using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
Aug 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSS dishwasher is totally dead as if it were unplugged. No response from front lights. Only 3 years old. Another post for an different Whirlpool model says it's the thermal fuse, but I...
If you have power going to the dishwasher, meaning the breaker, switches, wiring and fuses in the home are okay, the most common cause for your symptoms is the thermal fuse.
The thermal fuse is a small disk shaped device that is behind the control panel on the right side it is snapped on to the electronic module. The part number for your model is W10258275
Jul 24, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
After final rinse on my Whirlpool dishwasher panel went dead
Check your main power input. Switch off and ON. If no display
Internal fuse / circuit would have tripped.
Try replacing / Resetting. No improvement contact service center for assistance.
Apr 16, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Seems to have no power.
check where wiring connects to machine,make sure correct voltage is present at connection block.also check for blown fuse at connection block area.
Oct 16, 2009 | Whirlpool GU3600XTS Dishwasher
Dishwasher is dead, no start
there is a fuse just before power enters the control panelwhere the line goes in check that first bet its open
Jan 29, 2009 | Whirlpool 24 in. GU940SCG Built-in...
Whirlpool dishwasher won't drain and won't run cycles - it's dead
I would think the dish washer control panel has burned out.
May 01, 2017 | Dishwashers
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold dishwasher
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Jan 26, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Duet GHW9150P Front Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal De
