Question about Canon MultiPASS MP730 All-In-One InkJet Printer
"Wrong Cartridge" Worked fine for four years - Never seen the "Wrong Cartridge" messege. put in new cartidges - the right ones, just like the others, but still the same messege. Followed manual correction guide, but nothing. So... gentlemen... Has this happened to you and how did you fix it, other than buy a new printer?
  • 2 more comments
  • Brusso Apr 27, 2008
    posted by Brusso on Apr 27, 2008
    Report abuse
    Still need a solution for this problem?
    Try our Premium Assistance plan
  • Anonymous Apr 29, 2008
    WOW! I'm having the same problem. I have had this printer for four years also. It is no longer under warranty per Canon tech support and they wanted me to pay $9.95. I refused. The alarm light is blinking and there is an error message Wrong Cartridge on the LCD.
  • Vegsoft May 13, 2008
    I have one that is about 3 years and have the same issue
  • Mirandy Jun 03, 2008
    I have the same problem just started today--Alarm light on and "wrong cartridge" message on the display. I have no solutions at this point.
  • 147 Answers
Your printer cartridge carriage is short circuit. Try to repair it with the help of some technician.
Posted on Jun 25, 2009
Had printer cartridge refilled but when i put it back in the messege says incompatible ink cartridge-black
I would never use refilled ink. This is a lesson. You can still print, yet the cartridge needs a new "chip" they should have given you when they refilled it. You can try: remove the cart. turn off printer, unplug it, then put old cart back in. Do this three or four times and the memory of the printer can only remember three or four resets and then put refilled cart in. Hope this works for you. I was told this for an HP 7130 (similar, yet older version).
Brock
Sep 16, 2010 | HP 8500 Premier All-In-One InkJet Printer
I had been refilling my cartidgesand they worked well. Now, I refill my Cann bjc 250 cartidge, but the printer does not printp. I buy a new one. This cartidge worked well. Why the refilled cartidges do not...
when you refill a cartridge...they have a life spam...they do not last long...
because cartridge are manufacture to be use or refilled by 2 or 3 times...then if it reach the limit you have no choice other than to buy new one...
Feb 21, 2010 | Canon BJC 250 InkJet Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
Colour is wrong
Yes seen new color cartidges bad. Machine new should be under guaranteed also if cartridge does not work...
Dec 30, 2007 | Office Equipment & Supplies
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
HP Remove and check cartidge
usually, the error is because it's not recognizing the cartridge. Check the contacts on the printer and clean w/ alcohol. Are you using recycled cartridges or filling it yourself?
Oct 02, 2007 | HP PSC 2210 All-In-One InkJet Printer
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
Re:Canon Multipass C3500ex
Don, have you unplugged the printer for a few minutes? first the power plug, see if that clears it. If not, unplug it from the computer, reboot the computer, then plug printer back in. If not that,when an ink cartridge is refilled (depending on the model) the printer needs to be tricked into thinking a "new" cartidge is being installed. They make their money from the ink, not as much the printer. You may need to check the owners manual to see if the is the case. I have had to use tape to block off certain contacts, then remove the cartidge and block off another section of contacts, then remove tape all together and re-insert the cartridge.
Jan 27, 2007 | Canon MultiPASS MP370 All-In-One InkJet...
Remove and check color cartridge
try this. worked for me. when installing the cartridge, put one finger under the cartridge and hold upward pressure as you closed the green plastic cover. problem is the pins on the cartridge and the pins on the printer are not aligning properly by relying on the spring to do it. this will help to align the pins and should make it work.
Jan 10, 2007 | HP Photosmart 2610 All-In-One InkJet...
Brother 1950MC Print Problem
Listen, my friend had the same problem with his MFC 1950MC: "... have a Brother MFC 1950MC fax machine. I bought it used because I can't afford to buy a new one. I was told it was ok but it's not. It prints on only the right half of the paper. I was told by a 3 different authorized service centers that it's a common problem and requires a specific part that almost always fixes the problem. But, they won't tell me the part number or sell it to me. I think I found someone who will sell me the part if I can give them a part number. Anybody have any knowledge of this problem? If so, please help me out with a part number or solution. ..." Anyway, he found it on: http://www.worldoffax.com but he cant remmeber the part number. sorry. Hope it helps. K.
Sep 09, 2005 | Brother MFC 1950MC Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
139 people viewed this question
old marine
old marine
