Question about Sony KDF-E60A20 60 in. LCD HDTV
Kdfe60a20 My Sony KDF-E60A20 blinks red six times and then stops and then blinks six times again. I have ordered the thermal fuse but would like to know where I can get the service bulletin to replace this thermal fuse. Do you know where I can get this from?
  • 4 more comments
  • Anonymous May 16, 2008
    blinks red 6 times
  • Marla Roberts Quesenberry
    yes we are having the same problem... TV just cut off and the red light blinks then cuts off and starts blinking again.. I have orderd the thermo fuse from sony, but like everyone else where does it go?? We have the whole back off and hopefully when it comes in we can find which fuse it is. Any more suggestions??
  • mussman Jun 03, 2008
    My tv power light blinks red 6 times. I was told to replace the lamp, and did, but it didn't fix the problem. Please help.
  • Anonymous Jun 11, 2008
    hi my name is jeff and i have the same problem. thermal fuse.. defective.. i would really appreciate if you could send me a picture of exactly where this little bugger is.. ive taken off the back, and cant find it My e-mail is
    epcot_worldsfair@yahoo.com thanks
  • marysun59 Oct 25, 2008
    If I were to remove the thermal fuse would Radio Shack have it? I`m still under warranty but don`t want to wait 2 days,they won`t do warranty work on Sat.Thanks Easyride
  • canelita Feb 21, 2009
    Guys, I just wanted to say THANK YOU!! I replace the thermal fuse and it worked!.
    My KDF E60A20 was flashing six times. I order my part I received it today and now I can watch my TV again.
VERY Easy to change!!! We took the back off and on the right side by the fan is where it connects, just like KimSm said.. My husband called the shop and they wanted to charge 100 to come and look at it, 100 to take it with him if needed, 50 a night storage fee, 600-700 to fix it... He went as far to tell my husband there was no way we could fix it ourselves, there was soldering involved,circuit boards involved.. All lies!!! I just happened to stumble across this website and I am glad I did.. Saved a bunch of money. Thanks Everyone!!! Harley_Diva
Posted on Jun 03, 2008
  • 320 Answers
People, the whole reason for a thermal fuse is SAFETY! The thermal fuse is positioned by the lamp to prevent overheating and possible fire hazard. Leave the thermal fuse in the open cool air as some have recommended, but don't be surprised when the fir department visits you.
Posted on Oct 18, 2008
Guys... thanks so much... some other forums require advnced membership and **** like that....screw that!!!!! KIMSM knows exactly what to do.... Once I removed the back, it literally took about 30 seconds... thers a white clip that holds a wad of wires together, and in that bundle you will see only one clip that holds a gray/white color wire combo... .thats what you need... press the tab, remove the old, clip in the new, (it can only go one way) and you're done....
Posted on Aug 12, 2008
Where do you guys order the fuse?
Posted on Jun 01, 2008
    Problem Solver:
  • 7 Answers
Sony won't post anything. When you take off the back, it is on the right hand side. You will see the little fan there too. We wiped all the dust out very carefully including the little fan. We did not pull the old fuse out, we just detached it at the clip and clipped on the new one. This leaves the new thermal fuse out and it is now in a cooler area. If you attempt to remove the old to put the new in, in the same place, you will have a lot of unnecessary work. You will see the little clip to disconnect and just clip on the new one. The fuse is just a couple of wires connect together at the clip. Really simple, I did it myself with no instructions. Good Luck... Kim
Posted on May 22, 2008
  • KimSm Jun 01, 2008
    Hi Harley, When the thermal fuse comes, the new one will go on the right side (when looking at the back). There is a little white clip that you will see, disconnect it and put then connect the new one. You do not need to remove the old one, just leave it there, you would spend hours trying to get it out and it is not necessary. The thermal fuse is actual better out as it will stay cooler. We did a dust wipe while we were in there also including the little fan that is right there too. This only takes a few minutes. Kim
Why is power application erratic?
That is a Thermal Fuse. IT is behind the area where the lamp is. How to change the thermal fuse on sony kdf e60a20
This video is for a different model but its the same idea as yours.
Jun 08, 2015 | Sony KF-60WE610
Lcd projection tv kdfe60a20 6 red lights flashing on the power button tried to change bulb not the bulb
You have a blown thermal fuse.Replacement requires removal of the optical block.Not for an unskilled tech.Replace thermal fuse part#191002393 and clean all the fans.
Oct 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Looked and the thermal fuse is not broken
check again thermal fuse that you replace maybe wattage is not enough. there a lot of protection in that circuit.
May 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Picture will not come on
Most likely the thermal fuse has gone bad. Sony part # 191002393 Prett cheap part and east you replace.
May 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
Oct 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
May 07, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
767 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
