Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 Power
Opened unit to replace black ink and cartridges did not center so could not replace. Closed lid and now nothing works. Green power cord light is on. What is problem?
Talked to kodak servcice and they are sending replacement.
Posted on Apr 28, 2008
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1150 - how do I change ink cartridge
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center at the loading position. Squeeze the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges. (refer to sample image below. printer shown may not look like your printer, however, the steps are the same.)
Insert new cartridges. Color cartridge should be in the left carrier and the black in the right carrier. Snap the lid closed. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Thanks.
Nov 18, 2010 | Lexmark C533DN InkJet Printer
Kodak 5300 All In One Printer. Black ink quit printing.
Hi there.
It could be the chip in the cartridge... faulty for printing?
Settings in the printing process?
Iceman.
Nov 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Bought a new ink cartridge for 5300 printer - all photos were purple. Replaced ink cartridge with another new cartridge and now photos are green/yellow.
problem with printhead. go to www.kodak.com/go/printheadsupport and then try to remove printhead from printer. put it back again into carriage,install cartridges and then clean printhead from home center software. u r issue will be resolved
Jul 28, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 will not print black very bright
try doing a print head cleaning once or twice and try replacing the black ink cartridge and make sure it is genuine Kodak ink cartridge as there are many look alike and refill inks sold by retailers.......if still does not work print head issue and you may contact Kodak Tech support,,,,,,,,,,,
May 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 aio change inks
When you turn the printer off and back on you should hear a noise, when you lift the lid the cartridges moving to the center so you can replace them.
Jan 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink cartridge
You all need a new printhead. If the eyes on the demo sheet (copy and photo at the same time) are coming out all white and they look like zombies the black text isn't working properly. Try cleaning the printhead. If that doesn't work, call kodak, you need a new printhead.
Sep 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
62 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
