Question about HP iPAQ RX3715 Pocket PC
How to switch off my hp ipaq
Hi i have Hp iPAQ 4150 how to switch off
  • Anonymous May 05, 2008
    If i hold it too long, it will only turn off the backlight, but the unit will remain on.
  • 589 Answers
On most HP pocket PC's, holding the power button momentarily will turn it off.
If you hold it too long, it will only turn off the backlight, but the unit will remain on.
Posted on Apr 27, 2008
    Problem Solver:
  • 15 Answers
Actully, the IPAQs have a "sleep" button, but no "power-off". The only way to effect a "power-off" is to pull the battery
Posted on Dec 26, 2015
How to unlock hp ipaq hw6920?
The HP IPAQ HW6920 locked in which Country's Network ?
You can Unlock it using the Unlock code from the website
Superunlockcodes there you can get the Unlock code at low cost and unlock it,check code for your network lock,Country!!!!
HP IPAQ HW6920 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HP IPAQ HW6920 mobile phones. If you enter over a certain amount of wrong unlock codes on your HP IPAQ HW6920 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON the HP IPAQ HW6920 with a sim card that is Not accepted.
2 - The HP IPAQ HW6920 will prompt you for an unlock code.
3 - Enter the unlock code, which you can buy from our website.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your HP IPAQ HW6920 is locked to.
Each HP IPAQ HW6920 mobile phone has an unique unlock code. You can buy the unique unlock code for your HP IPAQ HW6920 mobile phone using the form above.
May 25, 2011 | HP iPAQ hw6920
Hi I treid to do a ROM update on my HP iPAQ 4150. The update stopped and the screen now shows 1.05H and 1.02 and only the HP logo. Does not go anyfurther. Furthermore the iPAQ is not recognized by...
I ran into the same issue with a H4150. Pull the main battery and let it sit without the battery for a while; a few seconds is not long enough. I let it sit for about two minutes and that was long enough on each of the four times I needed to recover from a failed ROM upgrade last night. This reset the H4150 and it then initialized like it was just out of the box; all data and settings were reset to original. Some troubleshooting procedures indicate you should not use a USB hub for this process. That did not work for me-the ROM upgrade still breaks the connection just after getting started. But at least pulling the battery got the iPAQ back to a useable condition. My next test will be to try it from an old PC with Windows 98 and USB 1.1 or 1.0. Maybe the brief disconnection is normal and a fast PC with a modern OS may not be as forgiving to brief upsets. Just as the ROM update really begins (after all the handshaking), the iPAQ briefly drops the connection and that's when the update fails, it just takes a little longer for the software to say 'hey-I've lost communication with the iPAQ...'
Oct 03, 2010 | HP iPAQ H3835 Pocket PC
Ipaq 4150 wpa Not connecting to WPA encrypted network. Worked with WEP
You will need to ensure that the Wireless Security settings on your router are set to at least 802.11 b/g and not just 802.11g, as the h4150 is a 802.11b device.
There is also a ROM update to 1.10 and a WLAN driver update to 2.0.53A available from HP as well for this device. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=349044&prodTypeId=215348&prodSeriesId=349042&swLang=8&taskId=135&swEnvOID=1087
Jan 15, 2010 | HP iPAQ H4150 Pocket PC
Replacing PDA Screen - HP iPAQ hx4700
http://www.repairhppda.com/video/How-to-Repair-for-HP-iPAQ-HX4700-HX4705-series.html
Jan 19, 2009 | HP iPAQ HX4700 Pocket PC
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
Problem
Hi, I have same problem. After upgrade bios to version 1.10 my ipaq h1940 don`t start windows. When switch ON appears HP logo, time line go to end, and ipaq stay block. No possible switch OFF and no starting windows.
Nov 16, 2007 | HP iPAQ H1940 Pocket PC
IPAQ 4150 & WiFi
hi i've never known them not come back on after going off, but have noticed they do switch back on, on their own when the wifi is enabled. when i want mine to stay off i tap the arrows at the top of the screen and select "turn on flight mode" this will then stop the device searching for a network and will shut down. when you want wifi again turn the flight mode of in the same way.
Sep 08, 2005 | HP iPAQ H4150 Pocket PC
4150 battery charging
When trying to charge the battery, do you get any Amber LED indicator on your iPAQ? It should be flashing when charging and solid when fully charged.
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
IPAQ 4150 - Sync Problems
It might be a hardware problem - if you get it both with the cradle and a sync cable, then it might be the connector at bottom of Ipaq. But I don't know for sure. If it's intermittent like this then it doesn't seem like a software problem.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
2,000 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
