Question about RCA Televison & Video
My HDTV wont turn on, two weeks ago the colors blend together I wasen't able to adjuste the colors. then I turn it off and leave for two weeks. when I try to turn it on it wont turn on, the control panel light never turn on also, but it make a click song twice after i push the power button. can you please give a clue. thanks.
  • 1 more comment
  • ccuya May 31, 2008
    I did replaced the fly-back transformer but it dosen't fix the problem, I also check continuity on the power supply glass fuse and is OK. I been advise that the problem is the green CRT, but I have to be sure about it, to invest more money on it. Thanks.
  • ccuya Jun 01, 2008
    I have 3 advises from you guys, but they are so diferents, I am not sure about what is causing this problem, i would like to have an advise that explain me well what caused thius failure. thanks
    Yes, kishkane if The TV is under warranty I will not put my hands on it, also about you sugestion of trash it and buy a new one said a lot about your technical skills. I wasen't looking for financial advice. thanks anyways.
    Genius:
  • 2,035 Answers
Well this is the problem with color in the tv set it works on the 3 primary color if any one color does not function it may lead to color difference.I would suggest you to follow IrishDruid suggestions as we can only give cause.................................................
Posted on Jun 01, 2008
    Scholar:
  • 198 Answers
This is a major problem faced by samsung lcd and hdtv customers these days.... The problem is with thte display not the audio system.. Don you have the warranty for this tv... how long its been since you bought it..if you have warranty its well n good other wise you have to take your mechanic who can fix the display for anywhere around $350 - $400...
Posted on May 31, 2008
  • 1 more comment
  • kishore swamy May 31, 2008
    My suggestion for you is that if it is costing more than $ 400 for you to get it fixed then pl go for a brand new set n trash tis off..... tis wil be the best option for you...
  • kishore swamy Jun 01, 2008
    unless your tv is manually checked on spot , the reason for its malfunction cant be told..... don u have warranty for your tv...
    thanks for ur suggestion irishdude
    President:
  • 2,712 Answers
It seems that you have an issue with the power board. You could also have faulty convergence modules causing the blending of colors.
I wouldn't advise you to open the set yourself, because of the complicated circuitry and high voltage. It is safest and best to get TV repairman to look at this issue and provide a fix/repair.
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Well, if the problem is just the CRT, that wouldn't cause the TV to stop powering up. You would just have convergence / video issues, and not power up issues. I am not saying that the green CRT is good, it could still be defective and needs replacement.
    The click sound is probably the power relay being energized. I think the issue is definitely to do with the power board / supply. Look for busted capacitor, etc. They should be easy enough to identify..they will have a swollen cap (top). Also check the relays, MOS, rectifier diode bridge, switching IC's, etc. It would probably be easier to simply replace the whole board.
    I'd recommend THIS link for a service manual for your TV. They also have many spare replacement parts, and they can help you locate the necessary parts online if need be. Also, if you purchase the service manual from, they will provide free unlimited online assistance while you install the necessary components.
    Hope that helps!
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    Well, as you can see, there can be many reasons for this issue, and only a spot check and testing can really pinpoint the cause. We are just providing all possible causes, but unfortunately, we cannot physically test anything ourselves.
  • Swilin Sampson
    @Kishkane: The gentleman said he already replaced the flyback..hence his warranty is already voided..
My RCA HD52W59 HDTV Television has double vision and red, green and blue colors separated like a spectrum in stead of all the colors blending together to make one uniform picture. What can I do?
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 09, 2010 | RCA HD52W59 HDTV Projection Television
I have a Niko LCD HDTV model OTP-3211W after a...
I'm having the same issue. Any luck wtih resolving this issue?
May 19, 2010 | Computers & Internet
Blue color on bottom screen and it is getting
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. You can find it here: http://www.discount-merchant.com/SONY-1-788-155-21-p/1179590.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
The color has changed to everything is tinted yellow or greenish have tried to adjust with remote, but no help
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
LG 32LF11 HDTV is haveing blurring issues, meaning that in some instances ( like digital art ) colors blend together or i should say bleed together, like if i take a red background and put a black line...
I have a similar issue with Samsung LN46N610. Red (and green to a lesser extent) text or graphics on light background creates something like a shadow or blurred edge. My PC is connected to HDTV via HDMI cable. I don't have this issue when I use Toshiba 46XV645U (Toshiba a different audio problem though) HDTV
Jan 03, 2010 | Televison & Video
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
The three colors are sereating,, like the spcetum is coming apart
Sounds like the converge has gone out. 2 parts that blend the colors together. I am looking into fixing mine by myself this time. They say if you can solder and follow a schematic, you should be able to fix it.
Oct 05, 2009 | Philips 60PP9202 60" Rear Projection...
Three colors are not together
OK, Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms. If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 22, 2008 | Philips 60PP9202 60" Rear Projection...
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
