Question about Evenflo PortAbout 3
No manual I brought an evenflo portabout carseat but it didnt come with a manual. Now I'm unsure about latches and locking clips etc. Where can i get a manual from?? Thanks
  • 2 more comments
  • crashedangel Apr 27, 2008
    Hi um I tried to copy and paste that link but nothing comes up, just a blank page etc
  • linrose84 Jul 02, 2008
    I have an evenflo portabout car seat I've taken apart to wash the fabrics. Now I'm unsure of how to put the belts back together.
  • Anonymous Apr 28, 2009
    I got nothing on that website too. And on the Evenflo site, the manual only comes in french............what gives?
  • mjyerovi Apr 29, 2009
    I don't have the manual, and still can't find out how to detach the carseat from the base ... can anyone help me!?
  • 502 Answers
Ask here, they can get you every Evenflo manual
Posted on Dec 17, 2010
  • 975 Answers
Copy paste this link to get a manual for this unit .
The PDF manual is available at : https://plweb.evenflo.com/ShowDocument.aspx?Manual ID=319
hope this helps.
Posted on Apr 27, 2008
The PortAbout 5 was last manufactured in 2005, making it very likely the seat has expired. Contact Evenflo (800-233-5921, www.evenflo.com) about the expiration date and reattaching the visor (if the seat has not expired). Please DO NOT use an expired seat!
Manufacturer states that, when installing this rear facing only restraint in an outboard seating position, there should be at least 1.5" of space between the restraint, including the handle, and the
back of the front seat.
Do not remove the harness strap from the adjuster. If the harness is ever mistakenly removed, Evenflo will send a new harness with adjuster.
-- Marc
May 31, 2013 | Evenflo PortAbout 5 Infant
Manual
You can find manuals for Evenflo car seats here:
http://babycare.manualsonline.com/manuals/mfg/evenflo/evenflo_car_seat_product_list.html
You can also contact customer service directly:
Evenflo Company, Inc.
1801 Commerce Drive
Piqua, Ohio 45356
Nov 16, 2012 | Evenflo Convertible Car Seat Booster...
Trying to adjust the child seatbelt harness higher in the carseat
I located my instruction manual for this carseat. It instructed me to turn the carseat over & located on the bottom are two metal brackets that lock the seatbelt harness. You just have to detach each metal bracket & pull through the bottom slots of the carseat, readjust each seatbelt to whatever level is necessary & push back through the bottom of the seat to lock securely. Thanks anyway for your help!
Apr 09, 2009 | Evenflo Baby Gear
Need to get the carseat apart for cleaning
You can download the manual from evenflo web site with your model number. You will be able to remove the 2 small metal clips at the bottom of the seat by twisting it gently. Then you insert it through the slot.
Mar 19, 2009 | Evenflo Embrace
Carseat rocks backwards when in rearfacing position
Depending on your seatbelts, you have to lean your body weight onto the car seat to make it tight.
Feb 02, 2009 | Evenflo PortAbout 3
How to adjust straps on the evenflo journey clairmont carseat?
You posted this in August so I'm not sure if you figured it out yet. I was loving this system until I ran into this problem tonight especially when I couldn't find this in the manual, but I figured it out. On the back of the car seat you'll see the black thingys that keeps the straps in place, above them are these two clips that you have to push down. push down the clip and pull the black thing up , it will release from car seat and from there you're able to adjust the straps height. I already contat evenflo about not putting this info in there manaul.
Aug 09, 2008 | Evenflo Journey Premier Stroller
How to install Evenflo Aura carseat into my vehicle properly
do you have the instructions?? if not goto ww.evenflo.com to get them they give you step by step directions on how to install your car seat! If you have a problem with the base not being tight and floping all over then try rolling a towel tightly and putting in the dip of your seat and then fastening the base down, I usually put to towel down then put the clip on the seat belt a little short of being able to fasten it in, so then I can put all my weight on the base and clip the latch in! It just makes it so much easier and a lot tighter then it would have been in the first place
Apr 01, 2008 | Evenflo Aura Elite Travel System Wedgewood...
Cover problem
You can get free user manuals on this address; https://plweb.evenflo.com/replacement_parts.aspx If it doesn't paste as a link then just copy and paste it into your browser. Hope this helps :)
Sep 16, 2007 | Evenflo PortAbout 3
Garage Sale Car Seat
If you push down on the top of the handle you should then be able to move it. Also, to remove the straps you have to feed the bottom portion of the straps from underneath the seat up through first and then you should be able to feed through the material to remove the pad.
Aug 18, 2007 | Evenflo PortAbout 5 Infant
Need help
https://plweb.evenflo.com/faq_detail.aspx?faqid=4990 Question: How do I care and clean for my PortAbout 3/PortAbout V infant car seat? Answer: To clean pad slide the elastic loops of the seat pad off of the seat shell. Remove the harness system. Cloth pad, canopy, and head support may be machine washed separately cold water, delicate cycle, tumble dry 10-15 minutes, low heat. Wipe straps, buckles, and harness adjusters with warm damp cloth and mild soap. Air dry. NOTE: DO NOT submerge harness assembly in water. To help protect the vehicle upholstery, place a towel beneath and behind the child restraint.
Feb 23, 2007 | Evenflo PortAbout 5 Infant
Evenflo PortAbout 3 Logo
480 people viewed this question
Top Evenflo Baby Gear Experts
Iron
Iron
Brian Sullivan
Brian Sullivan
Colin Stickland
Colin Stickland
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
