I have a brother Fax-1860C and it telling me to install a yellow cartridge. I have done this over & over a nothing happens it keep telling me the same thing. I purchased this fax from Office Depot on 3-13-07.
    Genius:
  • 3,587 Answers
Ok...when you put that yellow in, you'll need to do a clean and calibrate, before it will 'see' it..try that from the printer management panel
Posted on Apr 27, 2008
Error message regarding new ink cartridge
the cartridge is not put in good. make sure the tab that the ink came with is put in good then make sure the cartridge is clicked in all the way till the end. Then do a cleaning and a test run. Then you should be fine. If this does not solve your problem post to me and i will instruct you futher
Please rate me good
Jul 14, 2010 | Brother IntelliFax-1860C All-In-One InkJet...
Sais I am out of ink but I can see there is ink in the cartridge
the feeder may be clogged you can try running it through a cleaning cycle from the computer, if the ink appears to be under half way the cartridge may be bad/dried out at the nozzle. replace the cartridge.
May 21, 2010 | Brother IntelliFax-1860C Plain Paper...
Black ink not working on Brother Intellifax 1860C
All i needed to do, after messing with it non stop, was turn it off and reboot the machine. Simple solution! Thank god!
Apr 28, 2009 | Brother IntelliFax-1860C Plain Paper...
I replaced ink but it still says that ink is empty
HI,
please try to uninstall aagn the ink cartridge and check very carefully if you inserted it in his proper position.
after that try to turn it off your printer after 5 mins turn it on again.
let me know what happen next.
thanks,
Mar 17, 2009 | Brother IntelliFax 1860C Plain Paper...
Ink problem with Brother Fax 1860C
The machine detects the ink by shining a light through the rib in one edge of the ink cartridge. Apparently yellow is close enough to nothing at all, that the sensors get a little out of whack. Here's how to reset the sensors:
  1. Get a dinner plate or something to set the ink cartridges on, that won't absorb ink, and is easy to wash.
  2. Unplug the machine's power.
  3. Open the machine and remove all four inks, setting them on the plate.
  4. Close the machine.
  5. Plug in power.
  6. The machine will begin it's start-up procedure and complain about the missing inks. It will tell you to replace one specific ink first (black, I think).
  7. Follow the instructions on the display, installing one ink color at a time. When all four inks are in, it should be OK.
Use Brother inks. They have a little black floater in that rib, and some of the aftermarket inks have had a problem with the floater sticking.
There may be another problem causing this. The ink may really be low, or the sensor board may be off its mounts in the machine. But the routine above is quick & easy, and it fixes the problem more than half the time. You can't run without any of the colors, because that means air bubbles are getting into the ink tubes, and that can lead to dried ink blocking the nozzles.
This is unrelated, but when you peel the sealing tape from the bottom of the ink ctg., do it slowly. Brother has found that sometimes, when you strip the tape off too fast, a little glue remains stuck in the nozzle, blocking it. If that happens, dig the glue out carefully with a pin & it will be fine.
Nov 13, 2008 | Brother IntelliFax-1860C All-In-One InkJet...
Brother intellifax 1860c paper instlation
You can download the manual from Brother's website here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_1860C_1960C_MFC_3360C_EN_1424.PDF
Sep 10, 2008 | Brother IntelliFax 1860C Plain Paper...
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
35 people viewed this question
jasbo
jasbo
