Need a part for a Akia 1710W .rell to rell tape recorder. part required speed capstain.
  • 1,512 Answers
Hi hugh
I think that this is what you are asking for. Hit this link
If i got it wrong, ask me back here again.
Cheers mate
regards
Robotek
Posted on Apr 28, 2008
My akia gx 625 does not turn at required speed. What needs to be completed to resolve issue
The last time I had one of those and I do not work on them too often on purpose is the capstan shaft was glazed and the Pinch roller was never cleaned. There are ways to deal with the problems but most people are too lazy so they take it to a Technician. The Pinch roller if hard needs to go to Terry for rebuild and the capstan shaft can be reconditioned. The motor needs oiling. Akai used some bad transistors in their units that make noise and have other problems and the glue they used on the PCB sometimes eats the foils away.
Oct 09, 2016 | Audio Players & Recorders
After running approx. 25 tapes the player stopped working
Hi Ian.
Judging by reviews on Amazon, you're not alone in having trouble with the cassette player, which has multiple people decrying the quality of the unit
Audio Recorder 3 0 Plus with Cassette Player
That said, if the player hasn't just had some sort of internal mechanical failure, I'd recommend opening it up and gently turning the tape capstains with your fingers to see if they'll move. Try turning the player on with the door open but no tape inside to see if anything even spins. If there's been a mechanical failure, you're likely out of luck - cassette tape decks these days are getting rarer. If you're lucky, perhaps a bit of tape or some other debris has jammed up one of the capstains. In that case, you may be able to clean it up and see if it works then. If you've gone through the tapes fairly quickly, I'd suggest just returning the unit (your credit card likely as not has warranty-extensions built in if it's close on the warranty).
There are other tape decks out there, with a wide range of price, and, likely, quality, with USB out to let you play tapes to your PC. You may be able to use other options from there to get your tapes transferred.
Amazon com cassette player with USB out Software
Hoping this helps. Happy Holidays
D
Dec 14, 2015 | Honestech Audio Recorder 3.0 Plus W...
When recording two vhs tapes back to back on one disk, it will not finalize. But, will finalize if one tape is recorded. Mind you now each tape only has one half an hour recording on them, and the disk is...
The disc requires some space for the finalizing process. Two half-hour tapes take up all the room on the disc and leave nothing for the process. You'll need to record at a lower speed.
Feb 26, 2011 | Cameras
Hi, when I put a cassete in my tape deck TD-W315 the cassete runs very fast. It looks like a LP in 78 RPM? Does anybody can help me?
Check to see if the capstain roller is pressing against the capstain. Sometimes they get stuck or something has broke preventing it from pressing on the tape.
Sep 08, 2010 | JVC TD-W118 Single Cassette Deck
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
Poor EP playback
hi sir
the speed in EP is differ from sp ,EP it is much slow then all quality would be less cause you are using less magnetic particles on the tape so here are many reasons for bad recording
first may be you have to clean video heads
or ,you have to clean the path of the tape in the recorder there are some metal guides that turnes with the tape to get it rounds the heads they may be dirty
or clean the capstain pinch roller and its metal roller that makes it run ( the capstain roller )
or you should have new heasd drum sir
regards
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Emerson vcr #vcr755
have you tryed to clean the ace head??? The ace head means audio-control-erase. and is on the right side of the mechanism. this head looks like a big cassette type head and is statioary. This head can be cleaned just like an 8-track{remember those??}or cassette head by applying rubbing alcohol to a q-tip and clean the head from top to bottom. this head also may need cleaning if your tapes seem to speed up and slow down for no reason and at random. Thats because the lower part of the head is the control head and that gives the machine pulses to tell the machine what speed the tape is recorded in then the capstain motor has an fg sensor(freqency generator} and they all go thru a comparitor and the sum of both pulses gives the machine the proper speed setting. Hope this was laid out in understandable english. Good Luck
Apr 26, 2006 | Emerson EWV403 VHS VCR
 Grubhead
Grubhead
