Question about Brother MFC-5840CN All-In-One InkJet Printer
Unable to init.
I have turn the printer off and back on. I disconnected it from the network and unplugged it. I still get the same error. Can it be fixed, or do I need a new printer?
  • 487 Answers
To clear this please follow this link
BROTHER
Posted on May 10, 2008
DCP-J315W shows "Unable to Init 4F"
Turn off the printer and unplug it from the power. Then press and hold the power button for 1 minute. Now release the button, plug in the printer and turn it on and see if the error clears.
If it doesn't fix the issue, you probably have to replace the cartridges. They will cost about $65. Good luck!
Feb 02, 2016 | Brother DCP Office Equipment & Supplies
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
Unable to init.49
Turn off the printer and then unplug it from the power source.
Now press and hold the power (on/off) button for 1 minute.
Now release the button and plug the printer back in.
Turn it on and see if the error clears.
Let me know how this goes.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 03, 2014 | Brother MFC-J220 All-in-One Color Inkjet...
My printer Brother MF 5440-CN inject all in one is unBle print as it show unable init, machine error 4F.
Just checked a site - they suggest that you clear the purge counter, maybe this will help
Feb 29, 2012 | Office Equipment & Supplies
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
I have an error called "unable to Init. E3". how do u fix this?
Go to menu, network, restore factory default. The printer will restart. Then reset the WLAN per your home connection.
Feb 22, 2009 | Brother MFC 490cw Color Inkjet...
Unable to init massege erro
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Brother MFC 210C All-In-One InkJet Printer
UNABLE TO INIT
MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Nov 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
164 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
