Question about Technics SL-1200MK2 Turntable
Hi there. although my mk2 plays normally,sudenly i cannot hear it. i`ve checked wires and cartridge, what else it could be?
  • Technics Master
  • 5,515 Answers
You need to check that the signal is getting to the amp. This can be done by removing the wires off the cartridge for the left and right channels. With the amp on touch the ends of the wires. If you hear a buzz the signal is getting to the amp and the cartridge is dead, but if you hear nothing and if the wiring is as you say good. Then the pre-amp in your amp for the cartridge has failed. This pre-amp will only affect the record deck and no other functions. If it has gone you can trace the wires from the sockets to it. Sometimes it will be on a seperate PC board. It's often a single IC that has failed. If you can replace it yourself be careful with the new one as these are often static sensitive chips.
PS the phono scokets on the amp sometimes buzz if you pull the plugs in & out!
Posted on Aug 08, 2010
I have a technic 1200 mk2. Yesterday while spinning the speed started to vary. Not pressing anything, the turntable would speed up and slow down by it self (only a small bit, not going crazy) just enough where the songs sound sped up or slowed down. When i pressed the start/stop again to stop the turntable it doesnt stop right away. It takes about 10 seconds to stop, but as its slowing down the turntable jumps (not a smooth stop) Some small things i noticed, when i pressed play all the lights, would slightly (very very small difference) dim and flicker (very very light difference) Any ideas what it could be?
Posted on Sep 08, 2011
Sound not coming out loudly
You could have either a cartridge problem or a pre-amp problem.
To check. Remove all the wires to the cartridge. With the deck connected to the amp and powered up, set the volume at normal for what you would listen to it. Now with your finger touch each wire one at a time (it will not hurt you). You should hear a loud buzz on two of the wires, one on each channel.
If you do not hear a buzz or its weak, then either the connections between the deck and amp are faulty, or there is something wrong with the pre-amp for the magnetic cartridge inside your amp. If you have only recently connected the deck to your amp, it might be that your amp has no built in pre-amp, and you will need to purchase one. The internal pre-amp for the deck failure will not affect any other part of the amp.
If you do hear a loud buzz, check either the cartridge connections or replace the cartridge.
May 25, 2016 | Audio Players & Recorders
Kia Sedona 2002 (Mk2), the central locking locks itself randomly, although most often whilst closing the driver's door.
Try checking the central locking module as most of these problems cab be traced back to it being faulty
Feb 08, 2014 | Cars & Trucks
Crosley record player has tons of static and does not play very loud. Any suggestions?
Either a faulty cartridge or a faulty pre-amp in your amp. To determine which remove the wires to the cartridge. With the amp on at normal volume, with your finger touch each wire one at a time. You should hear a buzz on a channel from two of the wires and nothing on the other two (or very tiny buzz). If you do hear a decent buzz then the cartridge is faulty. If you don't or they are very weak, then the pre-amp inside your amp is faulty.
Jun 28, 2013 | Audio Players & Recorders
One channel won't play
With it connected to the amp remove the wires to the cartridge. With the amp on touch each wire with your finger one at a time. On one wire you should hear a loud buzz on the left. On other wire the right. The two other might produce a minor buzz or nothing at all, so ignore them. If you hear the buzz on both channels there's something wrong with the cartridge or the connection to it.
If you don't hear the buzz. Then (1) there's a bad connection between the deck and amp (phono plug or wire). (2) failed pre-amp inside the record deck itself. (3) failed pre-amp in the main amp. (this would not affect any other settings in the amp so tape decks will play normal etc).
May 26, 2012 | Denon Audio Players & Recorders
I've just bought a used Ion Audio TTUSB05 turnatable, I ve plugged it into my amp and it sounds terrible. There is a lot of noise before the needle hits the vinyl, presumably it needs earthing, when...
It will need earthing if you are getting hum. As it is used I would replace the entire cartridge and stylus with the best you can afford. Make certain you wire it up right. A good test is with the cartridge removed and your amp on, is to touch each wire (one at a time) with your finger. You should hear a buzz on two wires (one left one right) and nothing on the other two wires (earths). This will help you get the new one connected right.
Dec 01, 2010 | ION Audio TTUSB05 Turntable
Earthing/grounding problem with record-player/turntable
maybe check and see that the connections on your cartridge are all ok.
if they are in wrong ,that may cause that problem
Dec 21, 2009 | Audio Players & Recorders
I have 2 1210 mk2's and for some reason they only playing through one side of the stereo. I have tried tightening and loosening them to no avail, what should I try next??
The fact that both won't play points to a fault on your stereo! It's likely (if all other functions are good on it) that the fault is in the cartridge pre-amp of the amp. You can trace this by putting your finger on the left & right imputs of the imputs and tracing them allong the wires to the pre-amp section. You should hear a buzz if it's working.
Dec 21, 2009 | Technics SL-1200 Turntable
Hi,i got a problem with one of my technics 1210 mk2.Sound on the right monitor is ok,but there is not sound at all on the left monitor! I try to replace the stylus,but nothing....Please help?
Hi the only thing in between is the cartridge, wires and phono plugs at the back. There is a small circuit board (no electronics on it though) inside that the wires go to first. The possibility are , cartridge faulty (most likely i would guess), wire off the circuit board or the phono plugs/sockets at the back loose. Check the wires on the cartridge are ok as well. Have you also swopped the outputs just to check the cable to the mixer/amp?
Hope that helps
Jul 21, 2009 | Audio Players & Recorders
Print cartridge missing or not detected
Hi usually sensor of cartridge unit fail which send a wrong signal.
you may try:
1)take out cartridge unit looking carefully a tiny switch
at one side with a smal metal stander or a plastic button(you may hear click sound) just check this sensor position and adjust to normal where the sensor can active by the cartridge. put back cartridge test, do next if still not detect.
2) try to take out this sensor or check it's cable wire connection and using meter test, should be connect when click.
Dec 22, 2008 | HP Office Equipment & Supplies
Technics SL-1200MK2 Turntable Logo
388 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
