Question about Haier Heating & Cooling
Fan spiting water,dosent seem to drain - Haier Heating & Cooling
    Novelist:
    Champion:
  • 266 Answers
Make sure the unit is tilted toword the outside if this does not fix it the drain hole is plugged and you need to clean it out. There is a hole from the inside coil to the outside if it gets plugged it will drain inside.
Posted on Aug 08, 2010
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
I don't know what my error code means and my washer won't start
I had the same problem, My issue was a small sock that was sucked into the drain tube at the bottom of the washer. The technician removed the bottom panal and drained (a lot) of water from the tubing, then the sock came out, it had been preventing the water from draining out. It didn't seem to be a difficult repair to do on your own
Dec 20, 2013 | YouTube Videos
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Water
This ac unit will have to be taken apart and clean out the drain holes in the bottom of the case.Use a water hose to clean and wash it out,also remove any large objects by hand,of course you will have to remove the unit from the window to do this.
Apr 16, 2012 | DeLonghi PAC C120 12000 BTU Portable Air...
Dosent squeez the water
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dosent seem to clean as well as it use to leaves a film on the glasses
Check for unrestricted drain. The description sounds like dirty water...
Sep 20, 2009 | Dishwashers
Error code OE
The error is DE - DRAIN ERROR , Not fully drained out in spite of 5 min. drain operation
Possible causes
¥ The Filter clogged.
¥ The Drain Hose kinked or blocked.
¥ The Drain Pump/Motor or circuit is troubled.
Possible solutions
¥ Clean the Filter.
¥ Remove the cause of kink or block.
¥ Replace the Drain Pump/Motor or repair the Circuit.
Jul 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Heating & Cooling Logo
102 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
