Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hot point model hss25gfp. can get water at coupling but not out of door dispencer . ice maker works fine. When coupling is disconnected and water is depressed water flows fine from the coupling.
  • Hotpoint Master
  • 1,606 Answers
The water line is frozen in the door .Turn on the dispenser light for several hours , or , use a hair dryer aimed up into the dispenser , or , use compressed air in the tube going up into the bottom of the door ( computer cleaning bottle with a small tube ) , or , air compressor hose at the bottom of the door tube , or , order GE dispenser heater kit pt # WR49X10173 ( it comes with instructions ) . After you get it working , turn up ( warmer ) the freezer temp only slightly .
Posted on Aug 08, 2010
Testimonial: "Excellent solution I got the hose unfrozen and now the water valve died. Once I replace that I should be good to go. Heater is a must."
  • wcnabors Oct 04, 2010
    Placed small heater near water/ice dispenser for about 10min and water works again. This after I bought a $50 filter that didn't need to be changed!! Set freezer back to level 7.
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Tip
Hot point side by side with ice maker
My Hot point side by side has water and ice dispencer, when we use the ice maker the trap door stays open we have to close it by pushing it with our finger. We tried some lubricant on the hinges still stays open. We were wondering if there is a solinoid that acuates the door closed.
on Apr 30, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
Turned off ice cube maker. When I turned back on, water did not work.
no water to ice maker or no water to water dispencer. if ice maker how long did you wait for water to come out
Dec 21, 2009 | Hotpoint HSS25GFP Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
GE GSH25IHRB WW
My water line freezes. I have even had the door replaced and with the new door the line freezes. I use a hair dryer to warm it up and melt it. It's a pain, but saves me from buying a new refrigerator. (Which would definitely NOT be a Hot Point).
Feb 24, 2008 | Hotpoint HSS25GFP Side by Side...
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE Hot Point side by side Refrigerator
Okay this is pretty easy to find. Just trace where your water line comes into the back of the refer. You may have to remove the back panel. As you trace it in you will see where it comes to the valve. The solenoids are on the valve, one for the water (if you have water and ice in the door) and one for the ice maker. Both solenoids are on the same valve. If your ice maker runs and dumps fine and you don't have any water on the floor then it is your valve (water side) even though your ice maker is fine you may have to replace the whole valve as it is one unit.
Dec 26, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
491 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
