Question about HP Photosmart R727 Digital Camera
Locked card, that isnt locked.
When I turn the camera on, it says card is unreadable. If I press the button to take pictures it says Card has wrong format Press OK to format card. When I do that, it says card is locked- unlock card, which I have done. Marg
  • sofiagaribay Oct 07, 2008
    When I put my memory card in it says card unreadable , and then i click format card then it says card LOCKED unlock card. when its not even locked!
    Problem Solver:
Hi Try useing SDCARD FORMATTER V1.2 . This prog is put out by PANSONIC. i have used it to resuce quite a lotof sd cards.
Good Luck.
Douggie11
Posted on May 02, 2008
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
My agfa camera all working but put memory card unlock coming
The error you mentioned is usually when the memory card is unreadable because it is locked. If you check the picture below you can see that there is a lock button. If you slide it down the memory card will be locked and will not be readable, if you slide the button up it will be readable and will be unlocked!arjuun.jpg
Dec 06, 2010 | Agfa DC-730i / AP1100 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    My Kodak Easyshare caemra will only hold 3 photos.
    1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    If successful please give me the feedback as a rating or recommendation. Thank you
    Jan 10, 2010 | Kodak Easyshare 1725043 M893Is Digital...
    Memory card unreadable, card has wrong format, card is locked
    SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    Dec 26, 2009 | HP Photosmart R725 Digital Camera
    I have a new memory card. I cant get pictures
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
    Some how when then memorie card is in it it wont allow me to take pictures or anything it like i accidentally pressed a button wrong or a combination of buttons my son may have done it PLEASE HELP!!
    Please remove the memory card and try to take a picture...
    If the camera works then the memory card "Write Protect" slider switch is set to "Lock" or the memory card is bad.
    Please let us know what you find...
    -Jim
    Oct 17, 2009 | Cameras
    Card is unreadable
    Take out the card and transfer the photos to the computer. After you verify that your photos are safely on the computer, reinsert your card in the camera and proceed with the formating.
    Aug 03, 2009 | HP Photosmart R707 Digital Camera
    Menory card unreadable etc.
    ok check the card slot for the memory card the pins are bent... for shore
    Sep 03, 2008 | HP Photosmart R707 Digital Camera
    HP Photosmart R727 Digital Camera Logo
    244 people viewed this question
    Top HP Cameras Experts
    Fred Sops
    teddyboy
    Lawrence Oravetz
    Are you a HP Camera Expert? Answer questions, earn points and help others
