Question about Ovens
Hi The handle has fallen off my oven from Ikea Model number and details inside the door read; Ikea/wh ova11/s 501.427.52 pcm 18535 I'm sure this is still uner warranty as it was bought in august 2009 but all receipts are not available thanks
hotuna
  • 288 Answers
SOURCE: 3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Posted on Dec 06, 2007
SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 Fax 01628 776345 - Spares Email is spares@a1tech.co.uk
Posted on Apr 14, 2008
mastatech
  • 478 Answers
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Posted on Mar 12, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Posted on Jun 04, 2009
FixinFax
  • 3085 Answers
SOURCE: the inside glass has fallen out of the door.
http://ovendoorglue.com/?gclid=COaliI3t558CFYNo5QodvVPJHg
I have used this stuff, and it does the job.
Posted on Feb 10, 2010
Hi there i keep getting an F3 error message
that's a bad oven sensor,if you have a meter you can read it out it should read around 1080 ohms.you have a clock assy. or computer board same thing instead of an oven thermostat.unplug the stove pull it out from the wall,open the oven door and you'll see the sensor screwed onto the top back inside wall of the oven.remove the two screws,go in the back remove panel and you'll see the sensor wires usually on the back right side,you can unplug it and then pull it out from inside the oven,then slide the wires through the back wall,put in the screws go in the back and reconnect the wires.next time send the brand name and model number so whoever helps you can give you part number.go here put the model number in and you can look up your sensor
https://www.searspartsdirect.com/model-number/ETS22SBPBRBS/0432/0166000.html?searchType=modelSearch&q=ets22sbpbrbs&searchTerm=ets22sbpbrbs
Nov 13, 2017 | Ovens
My built in whirlpool fan oven mod no akz406/wh , has a fault code no f 01 on the display what is the fault and can it be fixed easily. I found loose connection in the socket the fault is still on
Hi, can you provide correct model number for this microwave? It is behind the door on the body of microwave on left hand side.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 06, 2017 | Whirlpool Ovens
Replace oven door handle
Hi blah_blah894 - Are you trying to replace the oven door handle or need part number? If so, I would like to further assist you but in order to do so; do you happen to have the exact model number?
Sep 27, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Wall oven, the front of the door has fallen off - glued on by the looks. So now instead of handle and window I now have one glass panel. I need to re glue it I presume. What glue would I use.
I am afraid that yours is a common problem. The front glass normally has some small brackets glued to the inside face, which then locate into the door frame.
This is the correct Heat Resistant Adhesive
Feb 11, 2011 | Fisher and Paykel AeroTech - OS302M...
The handle has fallen off my stainless steel kitchenaid superba oven and screws go from inside edge toward front. Can't tell how to access without removing frame and that's another question!
Yes the door has to be disassembled to repair the handle. In some cases you can just loosen the sides and top and work with it on your lap without removing from the unit but it takes patience and an extra set of hands is nice to have around. Any visible screws have to come out first. Eric
Aug 18, 2010 | KitchenAid Architect Series KEBC107KSS...
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Mar 12, 2009 | Ovens
Whirlpool Datid OV D10
i have an ov b 10 whirlpool/ikea oven that i have cleaned the thermostat knob numbers off. can i buy another set of numbers because my guess work is ruining my food!
thanks
Sep 05, 2008 | Smeg F170 Pyrolytic Stainless Steel...
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Removing Whirlpool oven door.
My whirpool ikea single oven door is broke can it be replaced
Jun 26, 2008 | Ovens
Ovens Logo
111 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
