Model: KFR-32GW/Ac Will not stop leaking water from the front of the unit. Coils have no ice. Shut off unit for 30 min the leaking stops but resumes when AC is turned back on.
    Novelist:
    Champion:
  • 266 Answers
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Posted on Aug 08, 2010
Dear sir i have room air condition model kFR-32GW/AC it is install in one of my room but i want to change it to another room kindly show me the method that how to close/stop the gas which outdoor...
Hi, look i am sorry to tell you but without special equipment one cannot do this, as soon as the gas line is broken, it must be re-pressurized again by the special machine that Aircon' installers have. As soon as the AC vents it's internal gases to the outside, it all must be re-set up again right from the beginning..
If one has all the equipment it is a simple task to lengthen the lines with suitable copper tubing and re-terminate at the AC, in its new position. Also simply lengthening the power connections too.
It cannot be worked on while pressurized at all.
AC usually have the Compressor outside and the AC Emitting Head inside, with Copper tubing in between to carry the gas or liquid as the case maybe.
Jun 18, 2011 | Heating & Cooling
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
My new Haier AC is icing up
it either needs a good cleaning on the coils and filter or it low on freon.
Jul 07, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Model #MSD2735GRW--leaking water inside the freezer and freezing 10 inches of ice on the bottom where the basket rests. cannot see any visible water leaking. HELP
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 07, 2009 | Refrigerators
Water leaking out through the frot door
Sep 14, 2009 | Refrigerators
Too much water coming out of the pan (in the front of the ice maker) and copper pipes on top left side are covered with ice.
Not real sure just what you are saying as to what pan? The copper pipes that go to the evap plates where the ice is made are supposed to frost over. They get colder than dew point of the air so this is normal. But all the pipes should frost. Does the unit shut down and give any type of beeping noises? This would be the control giving you a trouble code. You may have a water valve leaking. Turn unit off and see if water continues to run. All water should stop within a few seconds. Let me know what you find. Please verify model and serial numbers.
Aug 13, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Samsung window air conditioner model aw05ncm7 icing up not cooling
After I opened the front of the unit and discovered it full of ice, I left the unit off until it defrosted, so to speak, after the ice had melted, I turned the unit back on to see what happened. It is working fine now, I'm not sure why it iced up, if this is normal or not, but after it melted the problem was solved.
Jul 22, 2008 | Heating & Cooling
Ice maker leaking
shut off the water going into the unit if it stops doing it then your valve is bad as it is leaking by and filling the im too much
May 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Heating & Cooling Logo
203 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
