Question about Yamaha RX-V870 Receiver
No sound from right rear speaker yamaha v870. i switched speakers to eliminate that question
  • froehlyk Aug 08, 2010
    no that isnt the issue. the test tone fails to produce any sound from that speaker. fm or
    just amp. funny because there is no sound at all. the preamp should produce something
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
SOURCE: Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Posted on Feb 03, 2009
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Posted on Apr 14, 2009
  • 92 Answers
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
Posted on May 20, 2009
SOURCE: Speaker output
Yes, there are relay type switches associated with those outputs. Your RX-V1 is not dying.
Just plug a pin plug in and out of the dead channel to bump the switch. You will hear the speaker
come on. If it doesn't come on,do the plug jack in an out of the pre out again. It will come on.
You can use the test tone to check all channels and rebalance volume levels. You are making the
pre out connect to its power amp. It seems the problem got better when activating those switches. Most likely a cleaning issue. You can also jump the mains and center, and there is also
a modification to jump all channels. I bought my RX-V1 very cheap because of this and love it.
Of course outboard power amp would solve all, but getting this reciever to connect to it's own
power amp has been thrilling as far as bang for the buck. I do use the front effects also, and like
them. It may seem like a pain, but it is worth it to get those channels going.
Posted on May 31, 2009
I have no sound out of the front speakers. Mute button is off, speakers work fine. Only have sound (very little) if volume is turned way up.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's
full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume
it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape
Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead'
spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate
every control throughout its range a number of times, especially rarely-used ones like Tape
Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jul 10, 2011 | Yamaha RX-V870 Receiver
My 7 year old Yamaha RX-V870 receiver won't stay on. I press the power switch, the display lights up and after about three or four seconds, it turns off. Every time that I press the power switch the...
Get your service manual here:
Yamaha RX V870 Manuals
FIRST be SURE your speakers are connected! A loose wire can cause shutdowns as your Supply tries to protect your output transistors!
Your Yamaha also HAS a onboard DIAGNOSTIC feature but it won't do you much good now because your supply is going into emergency shutdown so quickly... see page 15.
Suspect a problem in your Power Supply.
*** WITH THE POWER DISCONNECTED ***
Inspect the electrolytic caps for leakage AND be sure the tops are flat and not bubbled.
Find your power supply on pages 46/47/48. It is VERY extensive and has MANY possible suspects. NOT for the weak of heart!
Anthony
Feb 04, 2018 | Yamaha RX-V870 Receiver
Yamaha RX-V995: Is there anyway to only listen to
Assuming you have the same Model Variant ( I'm not sure if Yamaha varies model from Country to Country) I just switch mine to effect off ( 2 Channel) to remove the surround component so that only A or B speaker pairs work.That should fix it unless I am mistaken.
Jul 19, 2010 | Yamaha RX-V995 Receiver
Volume keeps getting louder on the right
I solved the problem but i am not going to tell you how because you were trying to charge me money to get advise. that is bull ****!!!!!! give me a life time subscription for free and I will tell you my expert opinion
Aug 26, 2009 | Yamaha RX-V870 Receiver
Diplay dont work and no sound from speakers
Does it turn on? or does it "click" then a second later, "click" again? First thing to look at would be the internal fuse. Pull the top off the unit and check the fuse, it's located right near the AC input. If the fuse is ok, it needs serviced, if it's bad, you can find a replacement at radio shack. Hope this helps. If you need more help, just post a comment and I can help some more.
Jul 05, 2009 | Yamaha RX-V870 Receiver
Apr 14, 2009 | Yamaha HTR-5730 Receiver
Buzzing on certain speakers (but not all)
do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Feb 01, 2009 | Yamaha HTR-5840 Receiver
Yamaha RX-V870 receiver front right channel not working
There is a fuse in side the system you could try but that sounds like the channels is shorted, but yet again there could be a fuse for it
Nov 09, 2008 | Yamaha RX-V870 Receiver
No sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
Apr 27, 2008 | Yamaha DSPE390 Amplifier
Radio coming through on one channel?
Separate your speaker ground wires and ground them independently. Make sure you are grounding the speaker ground and not the positive!
Sep 18, 2017 | Yamaha RX-V870 Receiver
66 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
