Question about Jandy Laars Lt 400,000 Btu Heater
Where is the manual reset swith for an es1 fan fault on laars LT 400P
    Top Expert:
  • Jandy Master
  • 8,861 Answers
Turn unit off then turn back on check pressure switch and safety circuit
Posted on May 01, 2016
2 Suggested Answers
flacooo1
  • 172 Answers
SOURCE: Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Posted on Jun 15, 2009
Tip
Laars LX250 Manual Download
Laars LX250 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX250 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX250 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars Lt 250,000 Btu Heater
Tip
Laars LT250 Manual Download
Laars LT250 Installation & Operation Manual
Have you lost your Users Manual / Owner's Guide for your Laars LT250 Pool Heater?
Click here to download your pdf version of the Laars LT250 Pool Heater guide.
I hope that helps.
Jandy lxi 400p air flow fault
faulty air flow switch, blower isnt producing enough air pressure, or blockage in venting
Feb 06, 2012 | Teledyne Laars Laars Lx Pool Heater /...
Jandy LT400 ES1 light blinking because vent on top was blocked while unit was running
The manual manual says to check the flue (blower motor). The ES1 fault probably means emergency shutdown 1. When the flue was blocked it likely overheated something like the blower motor or some safety device and the system board is now detecting this problem and is indicating ES1.
If one of my customers had this issue then I would be prepared to open the heater and probe locations in the heater with a volt/ohm meter while on the phone with Jandy's technical support number, 800-822-7933. They are likely to help you diagnose this issue and recommend a repair.
Please let me know how this works. Thank you.
Sep 01, 2011 | Jandy Laars Lt 400,000 Btu Heater
Code says es1......what is it.... on laarslt heater
1. Flue gas vent switch tripped.
(manual reset)
1. Verify proper fan operation. Check for restriction or
blockage of flue. Reset switch after problem is
corrected.
2. Vent switch fault. 2. Identify and correct loose connections or replace
switch.
Refer to qualified service personnel.
3. Fusible link fault 3. Identify and correct loose connections or replace
fusible link.
This happens when the flue gases exceed a certain temperature. This only happens when there is a failed switch, or a bad burn created by incorrect gas or intake air, high wind scenerio or other similar incident to create an incorrect burn.
You may reset the switch manually, but it will most likely happen again, and if it does, its best to call out a technician.
Users manual can be found here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
Apr 14, 2011 | Teledyne Laars Laars LT Heater 400000 BTU...
Laars Lt spa heater service light
replace temp sensor its by the plumbing inlets or mounted to top of heat exchange
Feb 22, 2009 | Jandy Laars Lt 250,000 Btu Heater
Jandy Laars Lt 400,000 Btu Heater Logo
132 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
