Question about Graco Quattro Tour Travel System
Hi, I am missing one shoulder harness strap from my stroller. Where can I buy a new one or all 5 point harness strap set? Thank you for any help. Kate
Noggin
  • 944 Answers
SOURCE: help?
Here is the link for the user manual for your stroller; http://www.gracobaby.com/assets/pdfs/instructions/ISPA083AD.pdf if you dont find quite what you need in there,then check; http://www.gracobaby.com/customerservice/default.aspx Hope this helps :)
Posted on Apr 15, 2007
SOURCE: peg perego venezia
it has a free style harness it does not attact to anything look on the site if you havr any ? this feature is on all of the strollers it is so the baby can move but still can be held in and be safe. i hope this has helped
Posted on Mar 05, 2008
  • 29 Answers
SOURCE: Peg Perego Pliko 3 5 point harness strap
Contact Peg Perego
800-671-1701
Posted on Mar 17, 2009
SOURCE: i need a replacement 5 point harness
Contact Cosatto (based in Bolton) as they import Koochi products for retailers. They have a large spares department.
Posted on Apr 02, 2009
  • 91 Answers
SOURCE: adjusting the shoulder straps on the Maclaren volo stroller
What year is your Volo. Different years adjust differently. The newer ones have 3 height adjustment slots and a slider that adjusts the strap itself. They do not adjust way down though and even with teh straps as tight as they will go, they are still a little loose on my 15 month old granddaughter. I have found that buy tightening the waist straps it does keep her a little more secure.
Posted on Apr 10, 2009
My stroller has three levels to attach shoulder straps- where should straps be for a 6 month old?
Hi Marcia
We would think the harness setting should probably be on the lowest for a 6 month old baby / the most appropriate height for the baby depending on their height.
Please contact Maclaren for further assistance.
Sites maclaren US Site
Sep 08, 2013 | Maclaren Quest Stroller Standard
How do i move the straps to a higher/ lower **** ??
Hi
Undo the popper on the shoulder harness pads and slide pad down length of harness. You will reveal a metal D ring which is where the harness is attached to the anchor point. Unhook this ring. Remove the top of the seat fabric from the sub seat (seat frame) and you will find further sets of anchor points behind the fabric. Post required anchor point through the hole it lines up with and re-attach harness, then put harness pad back into position and do up popper.
Mar 24, 2012 | Quinny Buzz 3 - Rocking Black Stroller
My 2 year old can get out of bugaboo even though she is strapped in? Is there extra straps or a harness for bugaboo
The Bugaboo's like 99% of all strollers have a 5 point harness. Two shoulder straps Two Lap straps and a center strap with the main body of the buckles. 2 year olds become little Houdini's pulling the shoulder straps off in both strollers and car seats. There are small buckle units you can buy that lock the two shoulder straps at chest height these are excellent at keeping kids in their place. Ask any nursery supply shop they should have them.
Oct 10, 2011 | Bugaboo Baby Gear
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Im wanting the middle strap that the shoulder straps fasten into on my jane powertwin pushchair can i buy a new one from anywhere thanks jennie jackson
This sounds like you need the waist harness. I would suggest that you contact www.johnstonprams.co.uk who will be able to assist you in purchasing this,.
I hope this helps.
Sep 20, 2009 | Jane Powertwin - Navy Jogger Stroller
Where can I get a harness replacement for my stroller? Thanks i,m in the UK, my bugaboo frog aubergine has a broken harness from the seat frame, where can i get a replacement
Hi, I trust that you mean the waist straps? I would suggest that you contact www.bugaboo.com who will be able to assist you in purchasing these spares. If the problem is with the **** strap or shoulder harness parts, you may have to purchase a new seat fabric. I hope this helps.
May 30, 2009 | Bugaboo Frog - Aubergine Stroller
Firstwheels harness
To be honest i wouldnt bother buying the first wheels ones. They are very big and bulky should straps. I would reccomend buying some strap covers in black of ebay as they would be alot more comfortable than the first wheels. I took mine off and used some smaller mamas and papas ones. Hope that helps you
Mar 06, 2009 | Firstwheels City Elite Standard Stroller
Evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Dec 04, 2007 | Evenflo Aura Traditions Travel System...
Graco Quattro Tour Travel System Logo
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
