Question about HP Office Equipment & Supplies
Hi,i m getting DI.071B device failure error showing in my hp cm 8060MFP
2 Suggested Answers
Tnsiouxfalls
  • 617 Answers
SOURCE: Our HP Color LaserJet CM 3530 will not scan or print
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodTypeId=18972&prodSeriesId=3709253
This is HP's troubleshooting site for your printer.If you can't find what you need there's a "contact HP"button where you can talk with a tech.Good Luck!
Posted on Dec 31, 2009
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_beef7390c57fac0d
Jun 24, 2014 | United Stationers HP Photosmart C8180...
I have a printer hp CM8050 Color MFP showing error code D1.073B what is the problem
This was a problem previously answered here:
http://www.fixya.com/support/t18887496-hp_cm_8050_printer_showing_error_code
May 24, 2014 | HP Office Equipment & Supplies
Errror message www.bberror.com/bb10-0015
hi Sankaran,
go to repair shop and try to re install firmware.it will be ok.
regards,
nuwan
Jan 16, 2014 | Blackberry Q10
I have hp cm 8050 printer showing error code D1.073B
follow this steps and fix it. God bless you
Instructions
    • 1
      Ensure that the HP printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
    • 2
      Check the HP printer cartridges and print heads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the print heads. If an ink cartridges is empty, replace it with a new one.
    • Sponsored Links
    • 3
      Make sure that the HP printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the HP printer software.
    • 4
      See if your computer's firewall is preventing the HP printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
    • 5
      Check the print settings in the HP printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your HP printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the HP Solution Center.
    • 6
      Clean and align the printer cartridges. Open the software for your HP printer or the HP Solution Center to access these maintenance features.
    • 7
      Double-click on the HP printer icon in the system tray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
    • 8
      Navigate to the HP website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the HP printer's specific error. Also check the "Software and Downloads" area for software and driver updates.
Read more: http://www.ehow.com/how_4999655_fix-hp-printer-errors.html#ixzz2Z7d9rxWS
Jul 15, 2013 | Office Equipment & Supplies
Error code: "Scanner failure"
Hi
if your 7130 is showing "scanner failure," try resetting the date/time
If that fails, then your trouble's the motherboard, not the scanner assembly
I suggest you to get help from hp to replace the mother board of scanner
If this helps you please do a vote
Feb 26, 2010 | HP Officejet 7130 All-In-One InkJet...
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
I have the dreaded no audio device problem, tried reinstalling drivers no luck, tried the dell diagnostics and came up with error codes 1B22:061B & 1B22:071B, my Dell hardware warranty support has expired....
The error code , indicates that the sound card on the system has gone bad. You can call the OWR repairs dept for repair estimate on the same.
The second, less expensive alternative would be to install an external sound card in the laptop.
It would look something like this
http://www.soundblaster.com/products/product.asp?category=1&subcategory=844&product=17988&listby=
Thanks
proton
Mar 11, 2009 | Dell Inspiron 700M Notebook
Screen blacking out on Toshiba A25
Had the same problem often occuring in 2000 withy a 25 laptops and we traced this error down to failure of a small device inside & aside of the laptopscrean. When you open up the screanhousing you find it 1 cm width, half a cm deep and about 4,5 to 5 cm long (these days) . It converts the battery power into an higher voltage. Traced this divice down to the factory in the UK but these guys solely deliver these to Compac only (Stupid and shortsighted) Getronics repaired this failur only by replacing the entire screan upper body and then got some refund for the returned screan& upperbodies from Compac
When these devices can be obtained now from elswhere the problem can be fixed.
Rene
Feb 21, 2009 | Computers & Internet
186 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
