Question about Cycling
My boys aeon 50cc quad has been idle for 2 years in garage and now wont start ???? drained old petrol , fitted new spark plug, cleaned fuel filter and lines, fitted new battery .... still wont start grrrrrrrrrrrrrr any advice welcome
SOURCE: 2003 OLDS ALERO WONT START
Check to make sure the Security light in dash on right hand corner is not on. If it is on , your passlock is enabled. to dissable it turn your key on but not start it and wait for apx 10-15 minutes. this should re-set it.
Posted on Apr 15, 2009
  • 246 Answers
SOURCE: yard man gas push mower starts but wont stay running
Hello jusapup68:
>>Did you Soak the Carburetor when you Cleaned it?
>>If No, then the Carburetor can Still be the Problem.
>>Does the Engine Start and Quit if you Pour a Small Amount (1/4 oz of Gas into the Carburetor and Try to Start the Engine?
>>If Yes, then Soak the Carburetor Overnight.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select Shop Online Parts and Accessories. Now Select the Model Tab. Select the OEM (MTD) and Enter the Model Numbers. Now Double Click on the Model in the Results Area.
>>Have you Checked the Spark at the Plug?
>>Here is a Basic Instruction File I am in the Process of Making. It will Might Say Mower, but a Snow Thrower/Blower is Powered by the Same Type of Engine, so the Diagnostics are Basically the Same. >>***Here are some Diagnostic Instructions to Do on the Engine to Locate the Cause/Cure for a Hard/Not Starting Engine. This Does Not Include a Problem with the Valves. If I Suspected the Valves are Involved, then a Separate File for the Valves will be in this E-mail. This is a File in the Making, so Any Input is Appreciated.
>>1- Check the Spark. If Not Firing, then Replace the Plug.
>>2- If the Plug is Firing, then First, Pour a Small Amount of Gas (1oz) Into the Carburetor Throat with the Throttle at Full. With the Throttle Still at Full, Try to Start the Engine. If the Engine Starts and Quits, then Make Sure the Gas is Free Flowing to the Carburetor. If the Gas is Free Flowing, then Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk). I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning. You Only have to Remove the Bowl, Float Pin, Float and Needle Valve and Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed. Then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts. Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air. Install New Parts if Required.
>>3- If No Fire at the Plug, then Remove the Coil Shut Off Wire from the Kill Switch at the Engine Stop/Brake Bracket (where the End of the Stop/Brake Cable Attaches at the Engine). Check for Fire. If No Fire, then Remove the Blower Housing and Remove the Ground Wire from the Coil. Check for Fire. If Still No Fire, then the Coil is Bad. *On Some JD Model Mower the Engines Use an Igniter. Remove the Igniter and Coil and have your Local JD Dealer Test them for you.
>>* **On Models with Point Set, the Condenser is Bad and the Point Set and Condenser should be Replaced as a Unit. Make Sure the Point Set Plunger is Fully Extended when Setting the Point Set Gap to .020in.
>>** If there was No Response from the Engine When the Gas was Poured Into the Carburetor Throat and the Plug was Firing, then Check the Compression. If the Compression is Good, the Carburetor has Been Soaked and Cleaned and the Plug is Firing, then Check the Flywheel Key. If the Key is Damaged, then the Plug Firing is Incorrect to the Position of the Piston During the Compression (Power Stroke).
>>*** On the OHV and Some L-Head (Flat Head) Engines there is a Compression Release. The Exhaust Valve Clearance has to be Opened to .020in for the Compression Release Not to Operate; in Order to get a Correct Compression Reading.***
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 496 Answers
SOURCE: Yard-man model 12a-979L401 won't start (9 years old)
My dad always taught me, rest his soul, that basic 101, if you have gas getting to spark, SOMETHING out to happen.
I'll ask a series of questions and propose some possible solutions. Hopefully we'll crack this mystery. Warning, this might be a tad lengthy... ha
1. Is the spark plug firing?
To check the coil that sends spark to your spark plug and the plug itself:
You can remove the spark plug from your engine and reconnect it to the spark plug wire while it just lays on your mower. pull the starter rope (make sure you're holding down the kill lever on the handle). Look at your plug end as you pull the rope.
Got spark? If yes, go to the next step, flagged ***. If no, look at the end of your spark plug that would go into the engine. The "L" shaped finger should be gapped from the small circular shape on the plug... this is the "gap". Your manual may provide specs on how wide this gap should be. If there is no gap, your plug won't work properly. The "L" shape is a soft metal and can be bent... create the proper gap. Try the test again to see if the plug is sparking. If not, you may have an issue with your coil.
***Yes to spark. Let's look at the gas issue now. OPTION 1. I will tell you that in my experience, water in gas is a major culprit for a mower not running. You've replaced all the filters... good.
I'm not sure of your mower, but most models have a "bowl" bolted to the bottom of the carburator. Sometimes moisture can get in the gas, get trapped in the bowl and won't go away or won't allow gas to get to the spark. Loosen the bolt... it's ok if gas from the bowl spills from this, the bowl doesn't hold much gas and it won't drain your tank. Plus, this means your carbuator is allowing the gas from the tank to the bowl. As you are looking at the gas spilled on the mower deck, see if there are beads of water in it. As you know, water and gas doesn't mix. This would be a tell tale of the problem. I would carefully remove the bowl from the carb and wipe it dry, then reassemble the bowl.
To be on the for sure side that you have no more water in your system, you could disconnect your fuel line from the gas tank and drain it out. Use a jar or container... you can see water in the bottom of it. You can reuse the gas too... just don't include the water!
OPTION 2. If your carb and tank are now H2O free and you're still getting to results, you may have a clogged jet on your carburator. This little pin-hole passage allows gas to pass through to the spark. Sometimes a mower sitting up a while, can cause a laquer effect to gas and it can block this passage. Removal of the carburator from the engine is required and a simple pin can be pushed through this passage to knock a "plug" out.
Geez I hope I didn't miss anything! ha
Good luck to you... I hope it's a quick and easy fix.
Posted on Aug 26, 2009
  • 148 Answers
SOURCE: Starts and idles will not run above idle unless
Have you tried adjusting the carb? There should be two screws on the carb (hi & Low) turn the hi screw completely until it stops and then start the unit. Let it warm up and then begin to back the screw out until it starts to run smoothly but strong. Once you have it running then put it in full run position (choke) and you should be good.
Posted on Feb 20, 2010
  • 3 Answers
SOURCE: echo shred n vac starts,idles, runs to about half power then bogs
Check the grommet that sits on top of tank where lines from go carb. Grommet may be rotten and crack. Try that. Have you ever replace the carb repair kit? The diaphram may be torn, defoam or have holes in them. Carb kit cost arount $10, but don't mess with the welch plug or screen in carb.
Posted on Feb 22, 2010
Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
Two-Stroke Scooter / ATV Carburetor Settings And ...
? 4:37
https://www.youtube.com/watch?v=A1vRMERs4RQ
Jun 2, 2012 - Uploaded by 90GTVert
Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
Fix your Mini bike Carb - bogging, cutting out etc - YouTube
? 4:51
https://www.youtube.com/watch?v=lbtDMFUiD0k
Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
quad 50cc carb Questions & Answers - Fixya
www.fixya.com > Forum > Tags
50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
Aeon mini kolt 50cc quad will rev a little then cuts out no ...
Jan 05, 2016 | Factory Motorcycles
50cc scooter repair
Hi, Anonymous if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.
Toyota 3A Engine start up after sitting for 10 years prep work Vespa Scooter starts after 10 years of sitting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 11, 2013 | Beta Motorcycles
Aeon cobra quad won't start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
ATV Connection
Thread aeon cobra revo 100cc won start
https://www.tradebit.com/filesharing.php/search/0/aeon+cobra+quad http://www.racingplanetusa.com/index.php?shop_ID=1&sessID=6a91ecd9c6eef46bf7ef3dfc004d97fe&olevel0=2948&olevel1=&olevel2=&level0=4218&level1=&level2=
Aeon Cobra 220 2009
Mar 03, 2013 | Cobra Panther 100 Motorcycles
Peugeot speedfight wont start
Hi, Michellebym and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch, kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Peugeot Speedfight 2 Wont start
Peugeot speedfight 2 50cc won start Need help ASAP please
PEUGEOT SpeedFight 3 Workshop Manual
Peugeot SPEEDFIGHT 100 cc 1998 Parts
PEUGEOT Speedfight 2 Owner Manual
Sep 29, 2017 | 2007 Peugeot Speedfight Motorsport 50
My Mitsubushi Space Star Car won't Start. What can I try?
spark plugs are deep in the head yet you should get all the the old fuel out first, stale fuel wont ignite and will also clogg fuel filter. you need a mix of atleast 70% new fuel even then its not good for the injecters. If its a manual gearbox a tow start is a quick fix although no go for auto's. cant be much wrong if car was fine when parked, plugs-fuel-filter and possibly fuel pump for sure. If that doesnt fix take plug out put in lead and crank engine to be sure you have spark even just put any plug you know works in lead leaving your plugs in engine just to check for spark y turning over engine looking for spark on plug good spark will be blue but any spark is good.
Jun 16, 2012 | Mitsubishi Cars & Trucks
Scooter starts but stalls after a few seconds. It has been stored for a few months.
For more information about your question please visit the website below. Good luck and have a nice day.2012 Tao Tao 50cc scooter BMW C1 scooter stall at idle after normal start FOUND IT
My chinese scooter wont idle or start Check the fuel petcock
http://www.benelli-scooters.de/pdf/BA_Benelli_Velvet125.pdf
Benelli Velvet 150 2014 service manual DOWNLOAD FREE FULLMANUALS COM
May 20, 2010 | 2008 Benelli Velvet 150
Gv 250 wont stay running
read my solutions on this site for clogged carbs.....Tim
Jun 01, 2009 | 2002 Hyosung GV 250 Aquila
Gilera runner 50cc wont start
Don't do the gas down the spark plug thing. It's a bad idea. Do the following >
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
May 25, 2009 | 2005 Gilera Runner VX 125
Got a loncin explorer 90cc quad had trouble with starting it, since i bought it from new. took it back got a new battery and starter fitted at cost was fine for a week or so, but now wont start again, its...
ive bought 1 and had the same problem , change the spark plug for an ngk , and use shell v-power petrol ( or any other high octane fuel ) myn now starts first time every time :) and go's like stink also consider buying a better battery , the standard 1's are **** !
Mar 16, 2009 | Cycling
Cycling Logo
81 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
