Question about EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
I have a P4M900T-M2 mobo, and I would like to buy an Intel Q8400 (2.66G) 4mb 1333fsb. But P4M900T-M2 mobo says.. -> FSB 1066/800/533 MHz and an Intel Q8400 has FSB 1333Mhz Will the two of these work cooperatively? Will it have any problem/s or should I buy an Intel Core2Quad having only FSB 1066Mhz? Is it possible for P4M900T-M2 to support up to 1333Mhz? Thanks, :D
  • 11,800 Answers
No, the one you want will not work simply because it's too powerful for the board and will not be recognized. Here you can find all supported processors
http://www.cpu-upgrade.com/mb-ECS/P4M900T-M2(V1.0).html
as you can see the only ones for your mobo are Q6600 and Q6700.
Posted on Aug 08, 2010
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
What processor chips can this particular board handle
Support latest Intel Core2 Quad processor,Core 2 Duo,Pentium D,Pentium 4,Celeron D processor. Support 1066MHz FSB and DDR2 667
Jul 16, 2009 | EliteGroup ECS P4M900T-M2 Socket 775...
CPU compatability
It is not compatible. If your fsb is 533mhz then any replacement cpu would need to be a 533mhz fsb chip. This is unless your motherboard supports different fsb's. You will need to check your manual or the manufacturers website to see what cpu's your system supports. Hope this helps.
Jun 01, 2009 | Acer Aspire 5315 Notebook
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
Video card problem
this is probably a setting in the BIOS-setup you need to change. look within system/miscellaneous configurations for an option that defines which graphics adapter should be used as default. in normal circumstances there should be an auto-detect option...
Sep 03, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
RAM Installation.
your new ram fsb speed not support your mobo
845glly mobo support 266 fsb 133 mhz sdram
Feb 29, 2008 | Intel D845GLLY Motherboard
EliteGroup ECS P4M900T-M2 Socket 775 Motherboard Logo
414 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
