Question about Dane-Elec DaneElec 1GB Dog Tag External Black 1 GB Hard Drive
I need a driver for sd m02g - Dane-Elec DaneElec 1GB Dog Tag External Black 1 GB Hard Drive
I have a Quantaray SD card reader, I put a SD card in it and it doesn't work. I guess I need a driver or software in my Windows 7
Are you sure it's an SD card? If it's larger than 2GB then it's actually an SDHC card and won't work in devices designed only for SD cards.
Aug 05, 2013 | E-Machines eMachines Desktop PC
How to put SD Card in Dell Vostro 1310 PC Notebook SD card reader slot?
You will find the SD card holder to keep the SD card. then keep the sd card holder in the laptop slot.
You need to install the drivers of sd card reader also to work.
Jun 18, 2011 | Dell Vostro 1310 Notebook
Need win 7 drivers for SD SIL680-Raid card
try the vista driver it should work ok
32 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-32bit.zip
64 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-64bit.zip
if you found this useful please vote for me
Apr 22, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
I need to driver for this dvd rom please
i needs no driver but you need the Chipset driver.
with downloading and installing the chipset driver your problem will be solved.
if you tell me the model of your motherboard i send you the download link.
Jan 17, 2011 | Toshiba SD C2512 (SD-C2512) Internal DVD...
I have a 8gig sd card and my sr1519x cannot read it. Do I need different drivers?
If your card reader can access another sd card then your reader is fine. You do not need different drivers for different cards, you only need drivers for the reader itself. The card may not be accessible for usage until you format the card itself. If you don't have access to another sd card, go to the device manager and look for any yellow exclamation marks. If you see any, then you may need to update or re-install the drivers for the device. If you see the drive in my computer, try to right click on the device and a pop up window should appear to format the sd card. The only other thing that I can think of is that if you are using a card adapter, it may be locked to read and write data to the sd card. If so, there is a little slide switch on the adapter. I hope this helps.
Oct 26, 2009 | HP Compaq Presario SR1519X (882780153356)...
SD CARD is not working
I reccomend that if you can find a driver for your sd card slot, install it so that your slot could be compatible with all sd cards including HCSD cards.
Jan 26, 2009 | Acer Aspire 3690-2196 Notebook
Sd driver
Hi! You can click on this link http://tinyurl.com/SDdrivers so that you can download the SD drivers that is needed on your Toshiba laptop.
Hope this helps!!!!
Thanks
Sep 20, 2008 | Toshiba Tecra 9100 Notebook
Need driver for SD Card USB Drive for Windows 98
Check these driver :
1) http://www.lowrance.com/Downloads/Drivers-and-Firmware/MMCI-USB-11-Drivers-LEI/
2) http://www.sandisk.com/retail/driverdownloads.aspx
Jun 01, 2008 | Microsoft Windows 98 for PC
Recognizing / Reading SD Card?
Yes...go to the google website or drivers.com to find the driver of your computer and you can type the search box "dowload" your specific brand of you pc..............
Dec 16, 2007 | HP Compaq nc8230 Notebook
Sdio GPS
as far as I know the e750 supports the SD-Card I/O standard. You can check your system seettings, go to START - SETTINGS - SYSTEM - SYSTEM INFORMATION - DRIVERS There should be seen the SD/MMC Host driver, the SD/MMC Memory Driver and CF Card driver. Also if the gps card needs a driver, it should be installed also! Perhaps a system reset helps you in the end!
Sep 08, 2005 | Toshiba e750 Pocket PC
Dane-Elec DaneElec 1GB Dog Tag External Black 1 GB Hard Drive Logo
221 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
woodzowl307
pankaj rautela
pankaj rautela
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
