Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA210 has jam that I can't get out without taking it apart. How do I take it apart in the least invasive way possible? Thanks
  • 39 Answers
RESTART PRINTER OR TRY FOR REMOVING ANY JAM OBJECTS.
Posted on Aug 08, 2010
Canon ir4570 always jam at fuser
To properly solve the jam, you would have to start taking apart the machine, take the fuser out and inspect the paper path, a service manual would be helpful as the machines paper path in most cases is very complex, there are alot of moving parts in the path.
there is possibly a small piece of paper in the path, stuck in a gear or something similar, or a part is out of place or there is something in the path that doesn't belong there.
Aug 15, 2010 | Canon Office Equipment & Supplies
Paper Jam
Everything is held together by screws, (basic screws) Basically start opening all of the panels on the top and removing them. The doors will pop out at the sides and you should start seeing some screws. Just make sure you take pictures and put everything in order on a table that you take apart. After taking apart enough components, you will have access to the rollers. There will be screws on the back possibly also. Usually with all inkjet printers, you won't find screws on the bottom with the common brands. If you get stuck, let me know and I will have you post some pictures of where you are stuck. good luck
my best to you
Aug 06, 2008 | Canon I900D InkJet Photo Printer
Camera won't take a picture if the flash is
I had this exact problem with the same camera.
Here is how I got my flash to work.
Go to the play button, press menu.
Then, Go to setup and scroll all the way down to reset all...
Once pressing that, your camera should work.
Dec 04, 2009 | Canon PowerShot A530 Digital Camera
False paper jam
possible solution - I had a similar printer that had small stones that fell into the paper slot at the back and jammed the mechanism. a shelf behind the printer had these little rocks and a child dropped them into the printer. I had to take it all apart, but it worked after that
May 29, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Canon copier D760 paper jam
Try turning the computer off. Otherwise the printer should reset the sensor itself. Otherwise there might be some paper left in the machine. Keep taking it apart (without removing screws) until you are sure all the paper is out. Re post if problem remains.
paul
Nov 02, 2008 | Office Equipment & Supplies
Jamming
When these printer had a jam whatever is stuck in it is usually found deep down in the paper feeder where u can't visibly see it, to be certain nothing is stuck in there you'll need to take it apart, its not difficult as it contain just a few major components but be careful how you take it apart. You'll to take off the two side covers the scanner unit and the top cover then just a take flat screw and slightly raise the white plastic paper guide and see if its anything there.
Mar 25, 2008 | Canon PIXMA MP160 All-In-One Printer
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
195 people viewed this question
old marine
old marine
