Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
A bag of crab legs leaked how to get odor out and is there a drain an if so how do you clean it? I have cleaned with clorox.
    President:
  • 1,891 Answers
It does have a drain but it's not for this / to clean it use hot water and a tukey baster . the hot water will clear the tube and algi ect . mm the odor is best removed with baking soda. / wash it with soda and leave a box in the frig . mm
Posted on Aug 11, 2010
How do I cook crab legs for how long
  1. 1 Fill large stockpot or Dutch oven half full with water; add seafood seasoning and salt. Heat to boiling.
  2. 2 Add crab legs. Cook 3 to 5 minutes or just until heated. Remove with tongs to serving platter. Serve warm with melted butter.
Boiled Crab Legs recipe from Betty Crocker
www.bettycrocker.com/recipes/boiled-crab-legs/57fa96aa-ea80-4cf9-86d4-df935690b683 How do cook crab legs for how long Google Search
Dec 22, 2016 | Cars & Trucks
Discovery channel
Can be anywhere from $4.70/lb. to about $5.50/lb depending on the market. FYI - Opilio are also called Snow Crab. Information found at the attached link. Snow Crab FishChoice
Jul 23, 2014 | FishEx Alaskan Snow Crab Legs Opilio, sold...
BAD ODOR FROM DEFROSTED CRAB
I would suspect a leaky condensor,or leak in the refrigeration system,its gas oils are leaking out giving off an odor.get a professional refrigeration techncian to repair it ONLY!!!!.Warning do not try it your self.Harmful gases.
Apr 25, 2012 | Whirlpool Refrigerators
My soap tray is moldy, how do I clean it up?
pour some clorox or liquid bleach into it. Also run a wash of rags with clorox and vinegar a time or two and odors should clear up.
Oct 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
Odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
Fishy odor, how to clean or remove odor
This is a trick my wife uses when she stores fish in the refrigerator. Put about 2 cups of vinegar in the refrigerator and leave it there for 4-6 hours.
Let me know that works for you and please rate this!
Dec 09, 2008 | Whirlpool Refrigerators
I have a Magic Chef - Model # RB150AV - Serial # 11522453QF and it stinks. Clean out the drain pan. Vacuumed and cleaned out the coils and areas of compressor that had dust balls on it. It kind of...
There is not a lot that you can do to clean any more. If there is a hose from the drip pan to the evap coil you can see if that has any debris in it. Otherwise you are limited to using Clorox cleanup to wipe everything and then put baking soda in the unit with the just the lid off the box to absorb the odor. Keep in mind that there is not air flow THROUGH a refrigerator They seal to keep the cold in. So any odors that are in it cannot be expected to go away with the unit being used, like leaving the door open etc. That is why you need to use baking soda to absorb.
Sep 01, 2017 | Magic Chef Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
