Question about Alesis RA-150 Amplifier
I bought an Alesis RA-150 used on ebay. It started having a problem shortly after I got it and the problem it getting progressively worse. Each channel will intermittenly cut out suddenly (not at the same time), but if I turn the volume knob back and forth quickly a few times it will be okay. Then it may be fine for an hour or a day and then it will do it again. I appreciate your help with how to fix this.
  • 454 Answers
Sounds like the volume controls are dirty. You can try just working the volume controls up and down (amp off) that sometimes helps. If they are really dirty, you will either have to get some cleaner made for switches and pots (a spray can with the little tube) or take it to a reputable stereo or PA repair shop and have them fix it for you.
Posted on Aug 08, 2010
Not powering up at all
OK one thing at time first take cover off unit then check fuse if its blown there is a short do not replace fuse yet then locate bridge rectifier
check it for short if it is unsold-er and replace it then locate output transistors and check all of them for short. if one of the devices that i told you to check is bad then when you replace it then replace fuse and try powering up unit. be sure to replace all shorted parts before replacing fuse and powering it up. DE
Sep 12, 2011 | Alesis RA-150 Amplifier
I have an alesis ra 150 and a problem has happened that has never happened before. For some reason 'stereo' only comes out 1 speaker where as 'mono' comes out both. Can someone please tell me what is going...
Check for a stereo/ mono switch in the front or back, and make sure it wasn't accidentally switched in the wrong position. Also check and make sure the wires are not crossing each other causing a short.
Feb 19, 2011 | Alesis RA-150 Amplifier
Got an Alesis RA-150 off eBay to replace my RA-100, which worked great but I wanted more power. Was travelling when it arrived and my time to respond back to Seller has expired. With right channel set to...
it may be an open input side coupling capacitor in the feedback circuit around the power amp. if the amp has a limiter in it it may be stuck. here is the service manual, in any case.
http://forum.vegalab.ru/attachment.php?attachmentid=75690&d=1265371278
Dec 03, 2010 | Alesis RA-150 Amplifier
Alesis RA 500 makes a "clicking" sound and no more sound. later it will "click" on again
Clicking sound is a protection relay. This means one of the power amp sections have failed. Or that your speakers connections are faulty
Sep 24, 2010 | Alesis RA300 Amplifier
Audio problems with Alesis RA-150
on bridge mode the speaker impedance should be 8ohms, less than this clipping will happen. try bridging two 4 ohms in series.
if this happens without speaker connected, u have a power amp section that is trying to draw more power than it can handle.
as for the second check connections first, otherwise i suspect u have a defective power amp for the right channel.
Mar 12, 2010 | Alesis RA-150 Amplifier
The switch in the front which turns on the amplifier broke. I took off the switch with the two white and yellow wires. Not knowing i couldnt find a compatible switch..... help......
Try Digikey.com and Mouser.com.
If that centered oval thing is the power switch, it is LIKELY a special and you MAY have to go to Alesis to get a replacement... I hate it when they use specials...
The other thing is to see if the actual switch or mechanism MIGHT be the same as a part you can get via one of the sites mentioned above.
Jan 17, 2010 | Alesis RA-150 Amplifier
Alesis RS300 Reference Amplifier Channel malfunction...
You say "it seems like". Do you mean to say it is intermitent, or did it start cutting out and then finally fail? If that is the case I would look first to replacing the relay in contention in this thread.
http://www.fixya.com/support/t224708-amp_cuts_out_after_while
It's a cheap fix and will eliminate one potential cause. The Radio Shack part is widely available.
http://www.radioshack.com/product/index.jsp?productId=2062483
My RS-300 had started dropping the left channel, but occasionally both. It is possible that the relay has failed on one side and thus you have a dead channel...I did the fix and am now quite happy with the amp
Steve
Dec 26, 2009 | Alesis RA-150 Amplifier
Mmt-8 alesis squencer
HI...
Replace the memory battery.
Jan 16, 2009 | Alesis RA-150 Amplifier
Distortion in one channel
your right output component (transistor or integrated circuit needs to be replaced)
Nov 11, 2007 | Alesis RA-150 Amplifier
Alesis RA-150 Amplifier Logo
232 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
